Kentucky Turbo is doing TT my build
Old 08-21-2009, 10:31 PM
jeremym's Avatar
Default Kentucky Turbo is doing TT my build
Well with aps going to ****. I called kentucky and they are building me a Twin Turbo set up.all stainless steel with custom stainless headers.josh is going to use twin turbonetics 70mm with a .86 a/r housing and other stuff to spool fast.it is going on a 441ci LSX street car with a 6spd.I am using a big nasty custom LMR grind cam.he was so helpful and went out of his way to help out.the quality looks good. Who all has there kit and what power do u make?I have heard good stuff about them.how much power is the set up capable of? What fuel system would support it and what clutch would hold it.it should spool nasty. I am sure he might chime in.
Old 08-21-2009, 10:40 PM
svg210's Avatar
post pics please, I am going to hold off on my next big mod I really had faith in APS but 2800 plus Tax for Replacement turbos does not look pretty.
Old 08-21-2009, 10:42 PM
dudeman's Avatar
how much is that costing?
2 walbros should do the trick along with some big injectors and a boost referanced pressure regulator. not sure if the stock feed line will do it.
i hear monster clutches are supposed to be really good. i am thinking about getting the 4.5. it supposed to hold 775hp and have no chatter.
Old 08-21-2009, 11:19 PM
1fast bird's Avatar
You will definately need more than a stock fuel line for that....I have a twin setup from Kentucky Turbo...I will let you know how it runs when I finish it!
Old 08-21-2009, 11:29 PM
LS6427's Avatar
Originally Posted by jeremym
Well with aps going to ****. I called kentucky and they are building me a Twin Turbo set up.all stainless steel with custom stainless headers.josh is going to use twin turbonetics 67mm with a smaller housing and other stuff to spool fast.it is going on a 441ci LSX street car with a 6spd.I am using a big nasty custom LMR grind cam.he was so helpful and went out of his way to help out.the quality looks good. Who all has there kit and what power do u make?I have heard good stuff about them.how much power is the set up capable of? What fuel system would support it and what clutch would hold it.it should spool nasty. I am sure he might chime in.
NRE makes 1850 FWHP with a 427ci TT...but they use 78mm turbos. So you should be right in there with your guess of 1,300 RWHP.
What heads and intake you planning? 6 bolt heads I hope.
Old 08-22-2009, 12:24 AM
LilJayV10's Avatar
subscribing.
Are you keeping A/C? Tubular K member? I know you can make a **** load of power with a TC76 but I too am interested in a twin kit.
Best of luck. Can't wait to see pics.
Old 08-22-2009, 12:32 AM
LS6427's Avatar
Isn't 441 cubes a bit much for twin 67mm turbos?
Wouldn't you be better off with a 408ci?
Old 08-22-2009, 12:45 AM
Gordon0652's Avatar
That power through a 6-speed... outch!
Keep up posted! Goodluck!
Old 08-22-2009, 12:59 AM
Restricted User
98Z28CobraKiller's Avatar
Nice. 441 seems like alot of cubes for those turbos. My friend has a similar setup with the small housings and it's instantly spooled as soon as he hits the gas and he has a standard iron 408 (4.00X4.035). Josh is currently building a twin TC78 setup for another friend of mine. That'll prob be a 427. Can't wait to tune on that.
Old 08-22-2009, 01:50 AM
Reject's Avatar
oh man i cant wait to see some pix of Josh's setup. he always comes out with badass setups
Old 08-22-2009, 02:11 AM
MY99TAWS6's Avatar
Good luck having any six speed t56 survive at that hp level and torque level. Doubt anything but a triple disc clutch would have any chance to survive certainly no single.
No twin pump intank setup can support those power levels. and you would need huge lines and don't forget huge injectors like 160 pounders low impedence with all the related stuff likely standalone to tune it. And massive external pump or maybe triple intank setup.
What rear end are you going to be running? You will need to run a spool at those power levels posis won't live for long And t 67 sound do sound small.
And really hope turbonetics are better than a few years ago. Buddy went thru lots of them.
I would go garett for turbos they are pretty much the best out there.
gt35s or bigger. Ball bearing of course.
And don't forget your cooling system. Its going to have to be very serious as well.
And you better put in only the best engine parts at that power level.
So want to see how quick you can tear thru 30,000 plus with engine turbos, etc.
Plan a lot of money in reserve for all the little things that will come up.
Oh and just so you know. Much past 750 engine is not really that useable on the street and even on the track. I can run much more also but normally there is little point.
My current setup laughs at nittos,they are pretty much useless until into third even at 750 engine estimated. So you are pretty much forced to run drag tires 24/7. These suck in rain ,don't last long at all and dont ride or handle very good except for 1/4 mile driving.
I think 1000rwhp or even 800 rwhp builds make more sense but hey being a speed freak I can see the point of wanting 1500, 2000rwhp although after now having a pretty big power car realize it was pretty much just dick swinging.
Actually you can hook up fair amount of power by using various means to ramp in the boost and looking into a variable traction control setup for my car at some point. You can get better traction controls if you go standalone which likely you will anyway with your goals. So put aside another 4k or so for big stuff 3 by time you buy all the little extra goodies for it.
Old 08-22-2009, 05:11 AM
Frametwista's Avatar
sounds like u will have a killer setup.i have josh's tc78 kit and it looks very good and i also recieved excellent customer service he is a top notch guy imo.no #s yet still waiting to put it on.im sure u did alot of research on everything that will b needed so i wont tell u nothing like how much it costs and do u know whay your geeting yourself into unlike alot of others seem to do on this site.i say build what u want the way u want it not what people say will work on the street cause it is all their opinion anyway.there is alot of useful info though on this site but u cant listen to what everybody says so good luck with the build
Old 08-22-2009, 11:56 AM
jeremym's Avatar
Do u have any pics? I would like see it if u do.the kit he is doing for me the turbos are behind the headlight area I belive?
Old 08-22-2009, 12:02 PM
HUNTER02SS's Avatar
You arein good hands with Josh.
Old 08-22-2009, 12:07 PM
theblur98ss's Avatar
Should be a killer setup that makes huge power. I agree with others though about the setup. Turbos seem small for those cubes. I hope you've thought out the rest of the build too. Depending on what you have now that whole car is going need to be overhauled.
Old 08-22-2009, 12:22 PM
jeremym's Avatar
i am using TEA/TFS 235 heads and a ported FAST 90/90,jessel rr,and the new short travel comp lifters. i really am not trying to max it out and i know the fast would probably blow up any way.i just want to make 1100rwhp i know when u max thing out somtimes **** brakes. clutches,etc,etc .This is a street car so i will drive around making 800-900rwhp. I have mcloed twin disk.
Old 08-22-2009, 12:30 PM
jeremym's Avatar
this is a street car. i like the supra hwy racing.i wanted instant spool.
Old 08-22-2009, 12:37 PM
jeremym's Avatar
i am using that same set up but using #8 lines.I am using the ford racing 80's injectors.
Old 08-22-2009, 12:39 PM
jeremym's Avatar
what does everybody think of the turbonetics turbos? i have heard good stuff about prescion turbos.
Old 08-22-2009, 01:47 PM
GrahamHill's Avatar
Cant go wrong with Precision. People in outlaw 10.5 and drag radial are going stupid fast with Precision.
Quick Reply: Kentucky Turbo is doing TT my build
