HELP strange power cut please HELP
Old Aug 22, 2009 | 10:52 PM
sultan(ZR-1)KSA's Avatar
Default HELP strange power cut please HELP
Hi to you I need your HELP PLEASE all i haven’t been writing over here because I was busy rebuilding my motor after i destroyed three pistons.
make a story short and the rebuilt is done , i took the car to the dyno and didn’t have one clean nor decent run tell know , my car is a corvette twin turbo LPE last i have made with it was 672WHP dyno jet with old set up.
PLEASE HELP ME , now i am in a big dilemma and i am lost , while the car is on the dyno and i am WOT to do a tune the car starts very smooth and accelerates great all the way up to about 4K RPM and some times 5K RPM and it cuts in a very strange way you can have a look at the video here under at the minute 1:01
You can see that something very strange happens and the check engine comes on for a moment and then disappears ??????????????????
http://www.youtube.com/watch?v=tc3AiiiHO1k
Some thought was to a faulty Crank sensor, some a faulty Camshaft sensor, and some to faulty MAP sensor , when i did the DTC with the HP tuner it showed a miss fire but not permanent HELP
Here in video 2 you can see the tacho meter bouncing at about 5Krpm or so but the car did not CUT like it did the last couple of times but the tach bounced any gusses any takes HELP PLEASE
thanks
Please note this same thred was posted to COREVETTEFORUM
Old Aug 23, 2009 | 08:55 AM
Heeeeeeeeeeeelp
Old Aug 23, 2009 | 10:48 AM
venom ws7's Avatar
TTT for you man
I'll post my vid ASAP.
bounce
Old Aug 23, 2009 | 03:02 PM
Originally Posted by venom ws7
TTT for you man
thanks man i hope this will help a bit
Old Aug 23, 2009 | 04:18 PM
qqwqeqwrqwqtq's Avatar
Speed density or maf? Post your tune. Valvesprings?
Old Aug 23, 2009 | 04:42 PM
thanks for your help
it is a MAF tune , valve springs are 660 lift
my tune here under and also my scan for that run
File Type: hpt
File Type: hpl
Old Aug 23, 2009 | 06:35 PM
black98ws6ta's Avatar
Does it say reduced engine power on the diplay? Pretty common in a FI drive by wire car.
Old Aug 23, 2009 | 06:57 PM
nope it just goes back to regular like nothing hapend
Old Aug 23, 2009 | 07:07 PM
veee8's Avatar
What does the fuel system consist of?
Old Aug 23, 2009 | 08:11 PM
2 (044) -10 feed , -8 return boost refrinced FPR
Old Aug 24, 2009 | 09:47 AM
guys any takes on this ???
Old Aug 24, 2009 | 10:19 AM
veee8's Avatar
Do you have a fuel pressure gauge on the car? What does it do?
Old Aug 24, 2009 | 10:21 AM
Dewey's Avatar
you may have a cracked spark plug or a bad wire. a lot of the time that will only give you issues at high rpm or under load and show no signs of damage at idle or low speed.
Old Aug 24, 2009 | 11:37 AM
venom ws7's Avatar
I Dont think its the fuel pressuer we dynoed the car a 5-7 times and this problem happend 3 times maybe the AFR Is perfect I will try to post a graph today the car made over 650rwhp with 13-14psi with 12.1 - 12.2 AFR.
He changed the Wires before the dyno we thought about that and spark plugs are brand new.
Old Aug 24, 2009 | 01:06 PM
venom ws7's Avatar
Here is another vid I also have another I wil post it ASAP.
http://www.youtube.com/watch?v=gE9ae-HbjGg
Hussam
Old Aug 24, 2009 | 01:16 PM
veee8's Avatar
In that video it seemed like a rev limiter?????
It does it right when the speedo is buried.
Old Aug 24, 2009 | 01:20 PM
venom ws7's Avatar
Rev Limiter is set at 6800rpm I believe BTW it was KM/H not MPH.
The run just before this the car pulled hard to 6800rpm with great power and NO problems at all.
Old Aug 24, 2009 | 01:28 PM
Dewey's Avatar
when you changed the wires did you have trouble getting any of them off?
Old Aug 24, 2009 | 03:08 PM
veee8's Avatar
Yeah I figured it was KPH, I am curious, I wonder if there is a rpm limiter, and a fuel cut?????
