Enough with the 6 speed
Old Aug 31, 2009 | 07:44 AM
  #61
CP05GMC's Avatar
Originally Posted by 93camaro_zzz
I bet if you would have sent your first T56 to sixspeedsinc, you would have never had a problem. Just thinking that because theres hit 8's and pulled like a 1.3 60' and holds up.
Umm, I think his T-56 spent more time there than on the road. Not saying they didn't do good work and they didn't try every angle, from fluids, to no synchros, to anything else they could think of, but I believe the "6SPD TT" has run it's course.
Any chance to splice in a V160? You know it holds.
Old Aug 31, 2009 | 08:56 AM
  #62
slow67's Avatar
Gingervitis Addict
Originally Posted by Avengeance
Thats a helluva idea.... TH400 and GVO.
But he wouldn't have lockup then.......some converters may be too loose and will slip a lot on the highway.
Old Aug 31, 2009 | 10:47 AM
  #63
Tiago's Avatar
Talking
they built ALL my T56s thus far. Three of my t56s were identical build to their race car. Their motor didn't make TQ like mine does, and their car weighed more than 1k lbs less.
yup, they always did right by me, its just not going to hold unless some other gear metallurgies become available.
humm, this does suck... I would like lock up.
Old Aug 31, 2009 | 10:52 AM
  #64
speedracer5532's Avatar
My G-force T-56 is holding up with around 1000 rwhp once I decided to put a pump on it and always spray the input shaft gear/counter shaft gear. Only issue I have had with it is messing up 5th and 6th which are stock gears and you can't expect over drive gears to be able to handle that much power forever.
Old Aug 31, 2009 | 10:57 AM
  #65
mightyquickz28's Avatar
On a somewhat related topic,... what do you guys mean when you say some FI guy "blew thru the converter" on their automatics during a pass? That it's not ever hitting a 'stall speed' but just rev'ing rather than pulling?
  #66
Tiago's Avatar
from your sig you are missing 250 rw tq to compare
Old Aug 31, 2009 | 11:23 AM
  #67
stevieturbo's Avatar
So what do the TT Viper guys use with their T56's ?
Im sure they have the ability to make a little bit of torque.
Old Aug 31, 2009 | 11:30 AM
  #68
onfire's Avatar
Coal Mining Director
Lockup with a good turbo converter is useless on the street and track. I tried one.
Old Aug 31, 2009 | 11:33 AM
  #69
Zombie's Avatar
Welcome to the
Old Aug 31, 2009 | 11:35 AM
  #70
What do you mean? What happens? What are the characteristics of a 'good Turbo Converter'?
Old Aug 31, 2009 | 11:40 AM
  #71
smokinHawk's Avatar
when i priced everything out it made since for me to go with a th400 and get (when i could afford it) a GVOD
with those two it would be less then the 4l80e, and if it ever did break replacement parts are a lot cheaper, and easier to work on.
Old Aug 31, 2009 | 11:50 AM
  #72
I haven't dynoed it since I put the F1R on, but I know I am not as much torque as your turbo setup.
Old Aug 31, 2009 | 12:29 PM
  #73
Tiago's Avatar
Talking
they run Gforce setups, but they still break them regularly. They even crack the case and front plate. They have made some billet pieces but $$$ and rare to find.
please explain?
Are you running a 400?
Originally Posted by Zombie
Welcome to the
LOL... thanks for the laugh, that is awesome.
yea the pricing make sense, and it is a more proven setup from what I can find.
Old Aug 31, 2009 | 12:34 PM
  #74
With that much torque and power. Would it be a backward step to consider a TKO600 or similar ?
Its not like 6 gears would be necessary.
Old Aug 31, 2009 | 12:58 PM
  #75
slow67's Avatar
Gingervitis Addict
I'm referring to cruising down the highway, at rpms well below the stall speed of the converter.
I have less in my 4L80E setup than what a Gear Vendors unit by itself would cost.
Also, my tranny guy said that he wouldn't be afraid of shifting into OD at WOT with a 4L80E, up to about 1200rwhp....
Old Aug 31, 2009 | 01:20 PM
  #76
ddnspider's Avatar
Tiago,
Did any of your trans setups have the Mikronite finish on them like the ones T56 Rebuilds was offering.
  #77
98Z28CobraKiller's Avatar
Restricted User
+1. I can't see a built TH400 + GVOD being cheaper than a 4L80E even if you have to buy the controller for it as well. The 4L80E is the ultimate in maintaining streetability. I beleive that the 4L80E will also weigh less than the TH400 GVOD combo. I have also read that the GV OD is laggy in that it takes a sec to shift after you tell it to.
Old Aug 31, 2009 | 01:26 PM
  #78
Restricted User
The term "blowing thru the converter" means that the converter is slipping excessively up top. The converter is always slipping unless it is a lock-up so you can see that this is not a black and white kind of thing. I think that 3-8% slip is considered acceptable.
Old Aug 31, 2009 | 01:48 PM
  #79
Zombie's Avatar
less than 10% is what i've heard is acceptable as well... But I've also seen one or two guys on theturboforums.com say they've run faster with converters slipping 12-18% and lost a few tenths after tightening them up.
Old Aug 31, 2009 | 02:03 PM
  #80
Restricted User
Torque converters are full of fairy dust and magic. I don't know how they work but I know that they do...
