Possible new engine combo....
Old Nov 26, 2003 | 08:15 AM
Phil99vette's Avatar
7 Second Club
Default Possible new engine combo....
347cid
Total Engine Airflow Judson 6.0 heads
or
AFR heads
9.75:1 cr
ATI F1R 5.0:1
8 Rib
Spearco FMIC
Any thoughts?
Phillip
Old Nov 26, 2003 | 09:29 AM
MIGHTYMOUSE's Avatar
if you ever want to run on pump gas i would reccomend moving the compression to low9's as long as you keep your boost under say 12psi
Old Nov 26, 2003 | 09:47 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Pulleyed for how much boost?
9.75:1 compression is really gonna be a problem.
Old Nov 26, 2003 | 09:51 AM
7 Second Club
Probably 10-12psi on pump gas and higher on race fuel.
Phillip
Old Nov 26, 2003 | 09:54 AM
LS1Tech Co-Founder
9.75:1 and 10 - 12 psi on pump gas does not sound like a realistic combination, but maybe someone can give a real life example.
Old Nov 26, 2003 | 10:27 AM
mongse's Avatar
I ruin the end of films...
This
ATI F1R
would go in this
1999 Corvette Coupe
Are you sure it’ll even fit? C5 engine bays aren’t exactly spacious and fitting an F1R in an F-car frame isn’t easy w/o some frame cutting. Best of luck. Sounds like a vicious combo. I'd consider a CR around 8.7 or so if you want to really stretch out that F1R.
Old Nov 26, 2003 | 11:49 AM
7 Second Club
Originally Posted by mongse
This would go in this ?
I got a shoehorn.
Old Nov 26, 2003 | 12:48 PM
KHShapiro's Avatar
i am in agreement with the others that you should try for lower CR.
"I" would go with the 9/16 head stud aswell
you can't go wrong with what TEA offers in there stage 3 6.0l head the number are totaly awesome.
save the money on the pullies and go right to Cogs if you can.
F1R might be a little over kill for the ci but if you got a big cam do it up.
are you going Solid or Hydro?
Old Nov 27, 2003 | 09:36 PM
scottywheels's Avatar
if you are only going to run 10-12 then the F1-R is a waste of money.
Old Nov 28, 2003 | 02:28 AM
blueWS6's Avatar
thats exactly what i was thinking
Old Nov 28, 2003 | 03:10 AM
ChrisB's Avatar
How much power are you looking to make?
