LS2 APS w/ lg turbos
im just going to have to work with what i got. and ride it out
it sucks huge *** but what can i do
wish me luck guys that this piont i need all the help i can get
we got it al back together. it turns over alot better than before, its not draging like last time. it sound alot happer when you crank it.
so moving on to the "no spark". start using a flow chart and going over every little thing
with a scan tool i can see that the pcm is not picking up the cam sensor. i was told it should start without it but im going to get it working frist and than move on from there.
unless anyone has any more ideas about this let me know
right now i have aldata and a mac scan tool that im using to help me figure this out
But you said its working ,there is crank relearn procedure not sure if that has anything to do with your current problems. So you are saying you aren't getting spark?
No blown fuses ? No something not reconnected when you did the swap?
Also Tom did you buy bigger injectors for the bigger turbos? Or are you going to keep the boost down for a bit.? You need 80s for sure or bigger on there I would think.
i have a katech wire extenson for the swap. i have change the two outer wires on the extenson with no change but im going to take a go long look in to it today
I took one last drive with my car as an m6 today. Then mechanic buddy came over and tore it apart. Just bellhousing and clutch to take out and master. Buddy is all hyper to put it in his car. We don't have the luxury of overhead this is all done the old way in the garage on jack stands.
So hurry up and get that car of yours running..
it only has spark on 3 and 5 WTF ahhhhhhhhhhhhhhhh
ive talk to my bro all day who is a GM tech and way smarter than
im starting to think its something with crank sensor but it has rpm on the scan tool
Crank sensor messes things up bad.
You are sure computer plugs are in tight not sure if you took them out of computer during the recent swap. You can maybe try a different crank sensor they are pretty cheap I think. And you said you are swapping harnesses shortly?
