LS2 APS w/ lg turbos
Kidding of course..
I know zip about ls2s and tried to search on the net for you but came up with nothing.
Am very curious to see what it will be when you get it figured out.
thats the first thing i looked at guys but keep sending me ideas at this piont ill take anything
i have more data than most that i can help me ie aldata, scan tools,hp tuners and you all on here LOL
Seems to me if you are getting proper signal and power to the crank sensor then mabye the case learn thing is what you have to do.cam sensor don't stop it from starting.
And you said you have changed out crank sensor and ecu and coils.
crank sensor,ecu,coils have been chage out
its a good thing we have a lot of LS stuff laying around LOL
im going to put a harness in today and we will see what happens
also i put my computer in my boys car and it started right up it ran like **** be it started
i check the part numbers on the ls2 cam sensor ( its the tan color one) the wiring is in the right spot but its still has no cam singal but it should start something is wrong i just cant find it
Sounds like something is wrong with the wiring harness.
But seriously man did you get that new harness in there?
Unless some wires got damaged to the crank sensor and does his cam sensor work or not? You can see if it works in hptuners if you crank the car and set it on the scanner .The numbers start going up on cam sensor readings even if you only crank the car don't even have to start it up.Course cam sensor don't stop car from starting and running.
But then again you guys said you had crank signal on the scanners.
Car sure is making no sense. Can the reluctor wheel be out of position from when it pushed the crank ahead?
Could be vats with other ecu or case learn thing you can turn off vats in hptuners pretty sure or do vats relearn maybe.Thought case learn still let car run but not as sure on that.
Harness being wrong on the ls2 thought it was only for cam sensor and knock sensors but can a problem with it cause no start.
So it still just turns over and don't fire up or it fires and then stalls right away.
I had some weird issue where mine would start and then stall right away but finally it would start and stay running.It may have been an issue with 2.23 beta on hptuners.I switched back to 2.22 and so far its been fine. May have been some other setting that had whacked out. I never changed ecu in mine but did change OS to 2002 car with different vin. I did a vats relink in hptuners not sure had to but it was simple.
When swapping in my 408 we managed to somehow stretch a connector on the cam sensor connector so it was intermittent .Drove me nuts but eventually figured it out.
Being behind intake meant had to take intake off and then figured out could turn over the car not running and watch hptuners scanner and make sure cam sensor was working.It was worse in my case as was trying to run 120 low impedence and they won't stay running when cam sensor goes does. Car goes from sequential to batch fire and the big injectors don't work that way.
If ecu is not the issue would look hard at wire broken or pulled out of connector start checking wires with test to crank sensor and coils.
Really pulling for you to get this thing running Tom. I just went for a ride in my buddies 2001 z28 with my t56 transplanted into it. So looking at my car dead in garage waiting on the new trans. Might not get my car up till spring now and already going into boost withdrawal.Course have ticking time bomb APS turbos in there still to so maybe better dont' drive it anymore this year till get upgraded ones in.
I envy your weather..it was like 80 last week and today is like 48 out . And only going to start getting colder. Good news turbos love cold. ,bad news traction gets even more non existant!
Well rambling..will stay glued to the thread for some hopefully good news.
