LS2 APS w/ lg turbos
I think it has to be something with the crank reluctor wheel maybe from when the trans pushed it ahead. If its not ecu, wiring, coils, sensors the only other thing left that will make it act weird like that is something with the reluctor wheel and crank sensor.Read of another guy with similar problem reluctor wheel was on backwards??
You could still try vats link in hptuners and case relearn also. I would try both of them as last resorts and turning vats off in hptuners as well.
Good luck.
So what happened you lifted the afr 225s,thats one reason got them for the thicker deck.
Sure wish Tom would get his figured out but it must be internal. You have ls2 any other ideas on his problem?
So for now thats all.
Good to hear it wasn't fault of the afrs.
then i go to turn the key on to get the mileage for the dealer and i dont hear my oil pump running WTF its got power
im going to part this thing out if it keeps going like this
Do you know how much dirt there is just in the air?? Local guy at carshow showed up with his tt old dodge big block. No air cleaners at all.Dumb..just dumb.. but hey if you like buying new turbos.
Just kiddin
Thats just starting out...
Dont let it win.
