To much hp for the street
Depends on what you're gonna do with it.
Roll races......then there is no limit on whats too much. I know people with 1,300 RWHP who do nothing but roll races...its awesome to watch them do 50-180 runs, making bikes look silly. They hook just fine rolling into the throttle.
I'll be joining their ranks soon with my turbo LSX.
Racing from a dig "on the street"....that will be a problem hooking on the street from a dig.
Do as much HP as the pocket book will allow...worry about traction later.
If your just going to pull the car out to cruise around every once and a while I would go with a 1,000+hp build seeing as with a turbo or sc you can dial it in by either turning down the boost or pulling timing. So when you want the 1,200hp beast its there but you can cruise with the tame 800.
Even from a roll, my car lights up slicks or my big DRs at 60mph on 18psi.....even if I roll into it slightly.
I found current power setting of guessin around 600 to 650rwhp pretty nice for street driving. Fun but still pretty controllable assuming hot dry roads. I dont drive much in the rain and car dont' drive in winter only from about april 1 thru end of october. I drove it into novemenber last year but it got scary, not in snow but roads were cold and as said it got scary.I have no factory traction control.
Looking at doing a couple of things now with car. I am going to a high end street tire since it will be better in wet,better for ride quailty and less road noise and should last longer if dont' burn them all the time. Then have second set of rims with some et street raidals or similar mounted up if wsant to hook better track or off track.
Thinking of getting this aftermarket variable traction control made by Racelogic.
Also will try ramping in my boost with my eboost2 likely by rpm.
Advantage to turbo is you can change boost pressure easilyi. I have nitrous but only going to run smalll shots like 125 max. Its more a car show and intimidation thing since boost don't cost anything ,nitrous does but it will instant spool up the turbos and don't eat up any injector since its wet setup.
I am going to 4l80 and stall not many 6 speeds stand up reliably to really big power.
I don't plan on going past 1000rwhp max and that will be mostly dyno number. Most of time content to run in the 600 to 650rwhp range.
Get as much power as you can. Hope you have the right suspension parts, and more importantly the right tires to handle HIGH speeds unless your planning on shutting down @150 or less. Coilovers, road race style(toyo RA1's) tires.... all come into effect for a well rounded machine that can make severe lane changes when needed(never forget the time I had to dive across a few lanes @160-without any drama)(tires-suspension). But, thats me, not soo much into a DRAG setup, unless it's a dedicated DIG car, or unless you have multiple configurations(dig/road/roll).
As far as how to make the power?.. Thats on you. Every FI has there pros and cons. I have tried spray,centrifugal,and twins. To me, turbo is the only route to go but, everything can be a winning settup. For a 1000+spray car, you better have a controller and two-3 kits(not cheap-done right)(nitrous used to be the cheap way out-not soo much),... if you go with a blower,... do even mess aroud unless it's an 8 or 11 rib. If you don't know the difference in the two, consider a 305 tire(8 rib) compaired to a 345 tire(11 rib)... one has clearly more footprint, which means more grip/traction. For turbo(s).... the sky is the limit. Get good parts,.. it's that simple.
All require a 1000-2000 dollar parts only fuel system.
although I have 700hp on the streets and it gets a little boring because nothing can touch u. Plus I was spending $20 a day on gas. So now I am running nmca true street. With a th400. Racing on the street is just to dangerous. That was the point where the Formula way too hard to hook on the street. I did a hit once and the car was sideways for most of a block I could not get it to hook up, and I was on 28W's.
