Fireball Outlaw Drag Radial Rebuild Thread
Old 09-21-2010, 04:49 AM
  #741
njc.corp's Avatar
Looking real good
njc.corp is offline
Old 09-21-2010, 05:55 AM
  #742
Fireball's Avatar
underside of car is ready for paint...we finished the last of the seam sealing last night. Also mounted dzus tabs for the front of the hood. just need to secure the cowl "wings" on the hood.
just some minor fab work left, filling in the holes left from removing the factory side skirts and batwing and the car and some basic body work to take care of some dings and whatnot then will be be ready for paint
Fireball is offline
Old 09-24-2010, 10:54 AM
  #743
Fireball's Avatar
Engine bay is almost finished...did alot of small little jobs yesterday and this morning....
mounted the oil accumulator
mounted the coil packs
finished the cowl patch plate
cut excess off the shock towers,
some patch welding on the frame rails
I'll be on vacation until Thursday but should be ready to prime and paint the bay next weekend
will be painting it the same carbon fiber metallic as what I did the bumper, but will use flattening agent in the clear to take it to a satin gloss in the front wheel wells, firewall and frame rails. All the tubing will be painted with the hammered paint to match the cage...
Fireball is offline
Old 09-24-2010, 11:36 AM
  #744
trans2000am's Avatar
cool place to mount the coilpacks
trans2000am is offline
Old 09-24-2010, 11:39 AM
  #745
1fast bird's Avatar
I'm gonna do that with my coils!
1fast bird is offline
Old 09-25-2010, 07:03 AM
  #746
CarsandWomen's Avatar
is there somewhere that has lots of info on the car from before this rebuild? maybe like an original build thread? im interested to compare the before and afters
CarsandWomen is offline
Old 09-25-2010, 09:49 AM
  #747
Fireball's Avatar
look at the first post of this thread. I have a link to my original turbo build
Fireball is offline
Old 10-02-2010, 04:31 PM
  #748
Fireball's Avatar
made some more progress today...my glasstek fiberglass dash came in yesterday so I got it all mounted up...
two more pics of the gutted engine bay...
Fireball is offline
Old 10-02-2010, 08:08 PM
  #749
Coal Mining Director
onfire's Avatar
A lot of quality manhours in that build.
onfire is offline
Old 10-03-2010, 01:33 PM
  #750
1fast bird's Avatar
Looks really good Brian! Guess paint is gonna be done soon?
Old 10-03-2010, 03:32 PM
  #751
can you take a couple more pics of the coilpacks to see how you bolted them up
thanks
Old 10-03-2010, 03:37 PM
  #752
MUSTANGBRKR02's Avatar
Car looks sick!
MUSTANGBRKR02 is offline
Old 10-04-2010, 04:54 AM
  #753
Fireball's Avatar
thanks
I'm going to redo the brackets in aluminum...they are the same ones I built out of steel 2 years ago when I didn't have access to a tig
I'll take some pics when I rebuild them.
Fireball is offline
Old 10-06-2010, 06:37 AM
  #754
Fireball's Avatar
worked on it for 3 hours last night...
wrapped up a lot of little small things:
cut the old travel limiter tabs off the frame (had replaced to MADMAN's new style last year)
welded in nuts to hold the downpipes up better (I had just tapped the frame during mockup)
welded in nuts for the HVAC delete plate (its a pain to install when using a bolt and nut)
trimmed the passenger side shock tower
painted all the engine bay bars with 2 coats of HAMMERED paint.
Just need to add a little more seam sealer on the cowl (ran out...new can coming today), sand the bay, mask off the bars and the engine bay is ready for paint
I'm off work friday so maybe I'll get the bay painted
Once thats done I can start sanding priming and prepping all the body panels. Need to get this thing painted in the next 3 weeks since the weather will be cooling down quickly.
the RHS block should be showing up any day now (supposed to ship first week of oct). Shawn has most of the parts, but Phil needs to get the crank and rods down to him so he can start prepping everything. Said I should have it in 6 wks or so. should start coming together soon
we talked to ATI at the shakedown...they have some new tricks up their sleeve and will be modifying my converter to make it alot tighter
Fireball is offline
Old 10-08-2010, 04:41 PM
  #755
Fireball's Avatar
Got a few things done today...
fit up one of the DMH carbon fiber door panels:
Got the engine bay and front wheel wells painted too
Fireball is offline
Old 10-08-2010, 05:13 PM
  #756
wow that made a world of difference, before it def looks like its under construction, now it looks like its just takin time off for a mani peti LMAO
Old 10-09-2010, 07:12 AM
  #757
White.Lightning's Avatar
Where are the provisions for the bumpin' stereo speaker in those DMH door panels?!?!?
White.Lightning is offline
Old 10-09-2010, 09:30 AM
  #758
7 Second Club
Phil99vette's Avatar
Paint makes a world of difference, looks good buddy
Phil99vette is offline
Old 10-09-2010, 09:46 AM
  #759
3.8redbird's Avatar
Im new to the big power drag racing cars but what weight distribution is good?
I know for a roadrace car you want 50/50 and 25/25/25/25 but for drag racing do you orient it slightly to the rear as 45/55? I can see you why you would want 50/50 from driver to passenger still but more wight right over the rear would end up with better traction but to much ends up with massive wheel stands. AM I correct in this?
What is the goal weight?
3.8redbird is offline
Old 10-09-2010, 10:34 AM
  #760
7 Second Club
54-56% on the nose works fine.
Quick Reply: Fireball Outlaw Drag Radial Rebuild Thread
