Fireball Outlaw Drag Radial Rebuild Thread
Old 10-10-2011, 07:39 PM
  #1741
7 Second Club
atomicfusion's Avatar
congrats on your times, was really cool meeting you.
Looking forward to next year!
atomicfusion is offline
Old 10-10-2011, 11:18 PM
  #1742
Fbodyjunkie06's Avatar
Originally Posted by Fireball
two best timeslips...car 301
on the 7.746 run, I had lifted 2.5 seconds into the run for ~0.8 seconds due to the power wheelie. It was still way faster to 330 than my 7.723 run
So the converter is still kinda loose to the 1/8 but ok down the 1/4? Did you get the converter tightened up when you got the tranny fixed, swapped out or did you leave it alone? I remember you saying it was a 9.5" and should be a 10.5" while back, but not sure if it ever got changed. That 7.74@189 pass you were on a run there, especially lifting at 2.5 seconds in. you went 153@5.13 on the slower 60' run, but went 5.14@146, 7 mph slower due to lifting, if you'd been in it I bet that would of been a 4.8x 1/8!
Just wondering as me an nitroused383 were trying to figure out how much power you and another member who ran 7.5 at a lot less boost are getting the times your getting, and it's easy to see you were out the throttle now and other issues were keeping you from running to it's full potential. Makes sense now, good luck getting everything going full throttle!
Fbodyjunkie06 is offline
Old 10-11-2011, 09:40 AM
  #1743
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,143 Likes on 743 Posts
Wow you went 153.68 in the 1/8th on that one pass, dang!
Pro Stock John is offline
Old 10-11-2011, 10:01 AM
  #1744
Fireball's Avatar
the other pass was on its way to 162-164
Fireball is offline
Old 10-11-2011, 11:19 AM
  #1745
ProTreeRacing's Avatar
geez, your car always backhalfs awesome...40+mph?
ProTreeRacing is offline
Old 10-11-2011, 03:48 PM
  #1746
7 Second Club
Phil99vette's Avatar
Sounds about right.
Phil99vette is offline
Old 10-11-2011, 04:23 PM
  #1747
Fireball's Avatar
well...failure diagnosis is in...
Shortblock looks good. Going to get at least new rings and bearings. Heads are JUNK.
Looks like COP is coming off the car and going with a dizzy. We think timing jumped at some point. straps on plugs 3, 5, and 7 were burnt.
Crack in passenger head (across the plug holes)
blown out chamber in #6
Blown out chambers between 3 and 5
Attached Thumbnails Fireball Outlaw Drag Radial Rebuild Thread-chamber6.jpg   Fireball Outlaw Drag Radial Rebuild Thread-passenger_head_torch.jpg   Fireball Outlaw Drag Radial Rebuild Thread-passenger_head_crack.jpg
Fireball is offline
Old 10-11-2011, 04:28 PM
  #1748
Nitroused383's Avatar
Wow it's amazing to know how much you have left in this setup!
Nitroused383 is offline
Old 10-11-2011, 04:32 PM
  #1749
7 Second Club
I got some JB weld, be over in a minute, we'll have it fixed in no time.
Old 10-11-2011, 04:40 PM
  #1750
Hence why I said 4.8x!!!
Old 10-11-2011, 04:44 PM
  #1751
On the other hand we were chatting with Shawn during the live feed and he mentioned something about the shape of your intake port on the heads, being what was causing some of the spooling problems, I guess now you have an excuse to go to some nice rectangle port heads!
Old 10-11-2011, 04:46 PM
  #1752
Race your car!
JL ws-6's Avatar
Wow... heads are really junk! And those are the 1 off 265's too right? Can you even get those anymore?
Looks like it's time for something else no?
JL ws-6 is offline
Old 10-11-2011, 06:19 PM
  #1753
dschmittie1's Avatar
Ouch that hurts Brian when I got the text about the heads being cracked I was like WTF. Seeing the pictures makes it look 10 times worse than I pictured in my head.
Makes my junk lifter I found tonight pulling my heads to inspect for a blow head gasket look like nothing.
I am sure it will come out even more badass in the spring
dschmittie1 is offline
Old 10-11-2011, 10:29 PM
  #1754
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Wow! You just can't catch a break on things. What's the thought process on new heads?
Beaflag VonRathburg is offline
Old 10-12-2011, 06:20 AM
  #1755
Fireball's Avatar
well....I'm not constrained by anything at this point. MOZES is out since it takes WAY too much to make those happen in the lifter department. Doubt I'll stay cathedral anymore.
Fireball is offline
Old 10-12-2011, 06:46 AM
  #1756
FMX05's Avatar
Sweet Jesus those things are demolished. So if MOZEZ are out what about the All Pro LSW-2's? They look pretty sweet. At least you already have the right rockers... heh.
FMX05 is offline
Old 10-12-2011, 07:03 AM
  #1757
Fireball's Avatar
don't think so...the 265s used a unique offset so they are pretty much unusable
Fireball is offline
Old 10-12-2011, 07:20 AM
  #1758
FMX05's Avatar
Ouch. Where is the silver lining... hmm... it has to be around here somewhere.
FMX05 is offline
Old 10-12-2011, 07:40 AM
  #1759
3.8redbird's Avatar
Are your pistons coated? Were those heads coated?
Have you pulled the data from that run to see what happened?
3.8redbird is offline
Old 10-12-2011, 07:44 AM
  #1760
Hopefully no little chunks made it through your turbine wheel, looks like it all melted but you never know.
Quick Reply: Fireball Outlaw Drag Radial Rebuild Thread
