AMS-500 Boost Controller Plumbing
My first question (very vague in the instructions) is what goes into the "OUT" on the decrease solenoid?
I did find by using the search button that the noids should ideally be located 12-24 inches from the gate and should get a boost signal from the compressor housing.
Should I just "T" off the boost signal between the 2 noids, the top port on the wastegate and the MAP sensor on the controller itself like the diagram shows? I read that the AMS1000 guys are "T"ing off at the wastegate for the boost signal to the MAP.
Activation, I got input 1 down as it is going to the transbrake. If I read correctly, Input 2 wants to go on a WOT switch of some sort (no internal electronic WOT switch in this thing)?
On the AMS500, the MAP sensor is in the control module, so you have to run a vacuum line to the box itself. That said, should I put a "T" right at the wastegate and run it to the control box/module even though it is a couple feet away?
Also, in my instructions, it shows that the "INCREASE SOLENOID" should have air supply/boost entering in port #1 marked "IN" on the diagram. Port #2 marked "OUT" ties in to Port #1 marked "IN" on the "DECREASE SOLENOID". Port #3 marked "EXH" on the diagram shows that it should be plugged off.
On the "DECREASE NOID" port #3 marked "EXH" on the diagram has an arrow pointing to it showing not to plug it but port #2 marked "OUT" shows no plug but also has no notation to not plug it.
IE, lets say there is too much boost. It will energize the 'decrease solenoid' and turn off the 'increase solenoid' thus removing the pressure from the 'TOP' port of the wastegate and allowing the pressurized 'bottom port' push the waste gate valve open.
as for 'teeing' off the solenoids for the built in map signal, it should not matter. When the controller wants to see more boost, it will open the 'increase' solenoid to allow air into the 'line assembly'.
They are probably saying not to cap off the exhaust port on the 'decrease solenoid' because they only provide one cap.
Those solenoids are 3 way valves i believe.
When they are energized, air comes in from the 'in port' and goes thru the 'out port' BUT when they are 'de-energized' the channel closes, and they the 'outlet port' gets connected to the 'exhaust' port. So, they cap off the exhaust on the 'increase solenoid' that way, none of the air escapes out of the 'top port' of the waste gate.
hope this helps
If you are worried about crap getting in, there are little filter cones that you can install on those outlets.
