What cubic inches for d1sc
https://ls1tech.com/forums/forced-in...arger-lol.html
https://ls1tech.com/forums/forced-in...et-139mph.html
anything from 346 to under 400ci search Trust's threads he made over 800rwhp with 396ci Auto 12bolt car
with 400+ci you can get over 700rwhp with less boost though...
Anything larger makes the 'lil D-1SC work so hard the inlet air temps tend to run hotter. Bob
Most seem inclined to want to go to 402 or 408 with a D1 instead of just forged pistons leaving the crank stock.
Why not a forged 364 or 376?
Check out the above T/A. We managed to get 16 psi out of the D-1SC on the 402, but it was overworking the blower.
http://www.exoticperformanceplus.com...Car.php?car=12
Check out my Camaro in the above link. We managed to get 19 psi out of the F-1A with my 408, it was maxed out as well.
http://www.exoticperformanceplus.com...Car.php?car=51
Check out the above '08 Z06, where we built a Warhawk 427 and installed an F-1C, then we swapped the F-1C out for an F-1R. We then got 19 psi out of it. This engine had heads and an intake that flowed too well, this engine needed an F2 blower.
To answer your question, on a 427 I'd go with an F-1C or an F-1R. Bob
More torque. Bob
https://ls1tech.com/forums/forced-in...rap-fbody.html
These motors make so some much power and torque anyway at 10- 15 lbs of boost that I never did agree with the argument that you need a 402 or 408 for the street because of more torque. The LS3 is torquey enough for me and car will be all street - no drag.
My current setup is HC stock bottom end 347 with 8rib D1SC with a 4.38 pulley. On a very safe tune makes 565 rwhp on a Mustang Dnyo. So a forged pistons only LS3 376 should do me just fine as it won't be a drag car (1998 Z28).
How about a kit we can buy and bolt on for us that don't have access to CNC machinists?
I like the idea of a machined standoff bolt and pulley and longer belt much better than the SDCE setup selling for over $700.
