Boost by Gear or RPM
Time as said is only good at track. Rpm ok on street but gear think would great all the time.
If my stock motor does not take a poop at the track tomorrow I will probably do it to my car that also has a electronic 4l80e sometime soon.
So by gear we would have on turbo with say 7psi spring..
7 in 1st, 10 second, 12 third ,15 fourth on six speed manual car.
Auto maybe 7, 12, 15.
Now by time we could have say 7psi for first two seconds, 10psi for next three, 12psi for next three, 15pis for last two in a 10 second car.
By rpm something like 7psi 3000, 10psi4000, 12psi 5000, 15psi 60000
Just examples..
Is that clearer now. Rpm as said is easy to get working. One wire on eboost goes to tach output on ecu..
Time sounds like you need to hook up couple switches. not sure if momentary or on/off.
But no clue how to hook up gear based boost on my computer controlled 4l80.
they put littel microswitches on the manual cars for this.
I guess could be happy with rpm control on the street and time control at track maybe but gear again seems like it could be best for both. Also you have to hook up those external switches to the eboost to use time control? And do they have to be momentary both or one on /off or what exactly.
I ran boost per gear in my Z06 which worked great.
