My Latest T56 casualty
Tiago, we need vids now or ban
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
at the strip about 800rwhp and on the street its all about tracktion. If it doesnt track then it doesnt matter.
I have seen this a few times on the other 1k rwhp tans that I have done. What happens is all the fluid goes to the tail shaft or the rear of the trans and leave the input shaft dry. The lack of atf make the counter gear and input gear REALLY HOT and will shear teeth. What we have done is put a pump that feads atf to the adaptor plate so they always have fluid.
Rossler's and Circle D converter. Might need an adjustment... haven't fully tested it out yet.
Haighter- can you post up some pics of this lubrication mod?
I've heard of this on the endurance racing Dodge Vipers to make the T56 live.
I'm putting a built T56 (Viper OPS) into a 6.0 LS forged motor with GT88 turbo shooting for 1000rwhp. I hope that the low weight helps with lack of parts breakage. Goal is 3,000lbs with driver. Mazda FD RX-7 chassis
Tiago- Did you have a Viper OPS? That carnage looks nasty inside.
Bump to the top..... I've reached 1,000 posts
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
here it is: http://www.force-fed-fabrications.co...umpgasdyno.wmv
I'm positive Tiago had a faceplated t56. He posted a video of his car on the dyno and you could hear it
Bump to the top..... I've reached 1,000 posts![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#32
Sorry I dont have any pics but they are around if you look for them on the web.
#34
I know Tiago doesn't necessary agree with me but since I have been spraying the head gear/counter shaft gear I have had no problems with 1-4 gears. Here is my post on the lubrication mod I did. I am running a syncronized G-force T56. I did break the head set gear before putting the pump on and since the pump I have had no problems with 1-4 gears. I know over 20K miles with the pump with no problems. Last winter I took the tranny apart just to inspect it and the head set and counter shaft gear still look brand new. Lack on lubrication on those gears when applying lots of power is killer on them.
https://ls1tech.com/forums/manual-tr...h-hp-cars.html
#35
OWN3D BY MY PROF!
#36
#38
http://www.exoticperformanceplus.com...Car.php?car=11
At 809 rwhp in this GTO with a six speed, we snapped the pinion gear off the nine inch at this years LSX Shootout on it's first launch.
![](http://i226.photobucket.com/albums/dd185/EPP_photo/GTO13-1.jpg)
We got it back together and broke the output shaft in the transmission. Rodney at RPM Transmissions replaced the 27 spline shaft with a 32 spline shaft. How long it will last is anyone's guess at this horsepower level. Bob
ugh i can't win.
Join the T56 --> TH400 club tiago. i didn't want to do it either, but at least dropping a couple seconds in the 1/4 will help put a smile back on your face
