Highest HP out of a ZR1 to date!!
The idea is very simple, run the SC at lower rpm to give instant torque and boost. then once the turbos start to spool and put a positive presure before the SC, you open a valve that will bypass the SC direct the air into the intake (or the chaergecooler in the ZR1 case).
This way the SC is not restricting the turbos at higher rpm yet you still get instant boost with little to no lag.
'what about the power the SC will take?' well the SC wont actually be doing anything, just spinning away nice and freely as the presure will be the same on both sides of the blower.
Now that would be a KILLER setup! just have to find somewhere to stick 2 76++mm turbos!
Chris.
SICK car, I would love to make enough money to even afford to sit in the damn thing
I also plan on getting my modded ZR1 injectors from them...
Chris.
