Highest HP out of a ZR1 to date!!
Old Jan 26, 2010 | 09:27 PM
  #41
thirdgengta350's Avatar
Absolutely beautiful! i keep playing the idle video over and over and over. i could sleep to that noise. to some people that vid could be used very well as foreplay ;-) hahaha
Old Jan 27, 2010 | 12:53 AM
  #42
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Originally Posted by VIPRETR2
Lingenfelter has what you need.....
https://ls1tech.com/forums/new-produ...-pictures.html
Larry
Ouch, $1500... I bet a sheet metal setup could be made for considerably less. I guess it wouldn't have the OE look to it though.
Old Jan 27, 2010 | 01:08 AM
  #43
Wicked_C5's Avatar
Not sure about that. Sheet metal intakes are pricey!
Old Jan 27, 2010 | 08:15 PM
  #44
ProStreet_632's Avatar
There was alot of research done on the inlet by LPE and it should be a good solution to the restriction of air getting to the supercharger. For $1500 if it is efficient like they claim in the testing and it produces 20-30 rwhp, that would be a great buy. We talked to Tim today about it on the release date and they say in a couple weeks it should be available to the public.
Old Jan 28, 2010 | 05:06 PM
  #45
OWN3D BY MY PROF!
I agree with you that it is a good solution. What do you think lpe used when they started making their own?
It isn't an intake manifold, it is an inlet for the blower.
Old Feb 18, 2010 | 06:12 PM
  #46
MillsMotorvation's Avatar
I love it!!
Old Feb 24, 2010 | 09:32 PM
  #47
T-Bones Goat's Avatar
Originally Posted by VGLNTE1
but loose all the low end grunt. This blower out performs a centrifigal blower anyday.
Only 600lbs of torque at 3200. You're right Prochargers don't have low end grunt.
Old Feb 24, 2010 | 09:50 PM
  #48
LASTLS1's Avatar
6 Second Club Moderator
I'll second that!
Old Feb 24, 2010 | 11:15 PM
  #49
BigRich954RR's Avatar
I'd like to say Prochargering can make good tq down low I have 500tq at 2200rpms with max 806rwhp at 6800 I just wish I had a ZR1 too
Old Feb 24, 2010 | 11:36 PM
  #50
caddy03pimpin's Avatar
Remember that boost is simply the amount of restriction, its not airflow... So less boost or more efficient boost is equal to more airflow and more HP/TQ
Old Feb 25, 2010 | 08:37 AM
  #51
darkhorizon's Avatar
I would say belt slip...
Should have very slightly rising boost in a roots blower... no motor I have ever seen gets more efficient flow wise towards redline.
Old Jul 29, 2010 | 09:52 AM
  #52
sherm6998's Avatar
The torque curve is amazing!!!! You guys have some ***** tearing into a brand new
$130k+ car!!!
Old Jul 29, 2010 | 11:24 AM
  #53
ArthurJGuy's Avatar
600 RWTQ on a 1000 RWHP setup isn't low end, neither is 500 RWTQ on a 800 RWHP setup.
My TVS1900 makes 640 RWTQ on a 661 RWHP setup, The ZR1 makes 740 RWTQ with over 752 RWHP - THAT is low end.
You also have to take into consideration the power curves.
Old Jul 29, 2010 | 01:42 PM
  #54
Hennytime's Avatar
Originally Posted by Nickn20
Inlet restriction / inneffiency.
And for the love of god will people stop talking about putting turbos on top of the blower, its a restriction, you will NOT make some uber awesome hp doing this.
Guess you haven't heard the compound boost ford gt's out of unleashed tuning in jacksonville....those only make 1200rwhp
Old Jul 29, 2010 | 01:58 PM
  #55
02sleeperz28's Avatar
Awesome!
Old Jul 29, 2010 | 11:09 PM
  #56
COPO9560's Avatar
Can you share some details on this build? Power and torque are impressive!
Old Jul 29, 2010 | 11:41 PM
  #57
Fobra's Avatar
1200hp at 44lbs is not impressive... and it runs like ****.
compound is simply a gimmick for people who want a "bolt on" turbo system for a stock supercharged car. There is no point to it. Upgrade the s/c or buy the CORRECT size turbos. The hellion car is the prime example on the GT500. Makes around 800ish with compound... remove the s/c and it makes about 1000 on the boost. You can view hellions' own video on youtube if you doubt it.
Imo turbo>centri>twin screw>roots
Old Jul 30, 2010 | 02:11 AM
  #58
venom ws7's Avatar
I've seen GT500 with compound Hellion setup Twin 68mm turbos and stock blower it made 730rwhp with 17psi after that they removed the blower and put custom intake with the same boost made close to 800rwhp
So the stock blower is a freaking restriction but with those big turbos the car was so laggy on the street so the blower fixed that..
Old Jul 30, 2010 | 08:24 AM
  #59
Hennytime's Avatar
Exactly and idk how it ran like ****, it ha a pretty linear power curve and there was zero boost lag when I rode in torrie's car. And maybe it's just me the guy just pulled a 220mph standin mile so I'm missing the big restriction.
Old Jul 30, 2010 | 08:31 AM
  #60
Big_Bird_WS6's Avatar
is the ZR1 a MAF car. or is it Speed Density tuned from the factory?
