Please give your opinion of a gt-88 on my build
370 lq4 8.5:1cr, 317's, 228/228 cam, py3400, 4l80e, 4" downpipe
the truck is 90% street driven but never really fast on the street. I am only concerned about going fast at the track. How well would this spool on my setup on a 2step at the track?
I have been looking for a good deal for a pt88 but haven't found one yet(looked for almost 2 months now). This turbo was brought up to me by another member. Let me know when you guys think. Thanks in advance.
Forgot it's a 1.08 hotside. Right now it has a tc78 on it and I drive it everyday without going into boost. It doesn't bother me being slow on the street since I don't race on the street ever. I need to find a new turbo asap though since the tc78 is going on another truck soon.
not yet
I couldn't tell you. I have the same tune on it now as I did before the forged motor and cam so I have been just putting it around.
I have this cr now so when I decide to get new heads I will have better options and bring the cr up to 9.5~
It wont be SLOW on the street. Will just spool later and might not be as much "fun" to drive on the street as the track. The 88 isnt terrible. In my conversations with forced inductions the 88 spools about 400 RPMs later than lets say a 76GTS so its not terrible. With a stalled auto it should be fine on the street.
LS1Tech Co-Founder
I had a GT47-88 1.08 atop a 8:1 348 cid. My car spooled slow to me. If I was on the highway and nailed it in 3rd gear, it would not take off until the car got to about 5000 rpms. Now if I had my A3 in 2nd gear on the highyway and was holding the rpms to say 4500, and then got on it, it would take off pretty soon.
I use a 3500 stall in my truck with a Precision 72mm turbo and 6.0 engine with 8-1 compression. It 60 foots 1.7 at 5500 pounds but has dipped into the 1.6's a few times. Runs 11.40's at best with the 3500 and a two step set at 2500. I bump into the second light at full throttle with the two step at 2500, it makes 12 pounds.
Right now for better MPG I run the stock GM converter, it will only go about 2000rpm on the foot brake, that is 5 psi. It might have done a touch better when the engine was new, it has 104,000 boosted miles on it now and sounds a bit like a diesel!
Kurt
Kurt
