Start with LS1 or LS6 engine if blower planned ?
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Hello guys,
I'm new to this forum, just joined because I am in the process of selecting an engine for my Cobra replica.
I have pretty much narrowed it down to either an LS1 or LS6 engine.
My question: is it worth going for the LS6, if I want to supercharge it later ?
I'm asking because I think most of the differences are in the heads, which will have to (?) be replaced anyway to lower compression...
Any info much appreciated,
TIA,
Marcel
TIA,
Marcel
Originally Posted by mmelters
Hello guys,
TIA,
Marcel
TIA,
Marcel
Thanks for your opinions, the consensus seems to be to go with an LS1, unless I decide not to go for a charger after all...
Kind of hard to judge whether it will be worthwhile to charge an LS1 vs. a N/A LS6.
Oh well, I have some time to decide; maybe an LS2 crate engine will be available by next summer ;-) That should keep me happy for some time..
Thanks,
Marcel
Thanks,
Marcel
Thanks,
Marcel
Thanks,
Marcel
The best thing about FI is that you can make the car have perfect street maners until you put your foot into it , then it turns into a screaming race car. The high hp NA cars that I have been in seem to be a little rough around the edges on the street.
The block are not identical. The LS6 is vented on the skirts to prevent windage problems. If you are planning on a new block there is very little price difference and the LS6 will relieve crankcase prressure better than the LS1 and allow for better oil flow and cooling.
Cam and heads are going to be after market. You can still bolt a set of LS1 ported heads onto them and since FI is your goal, head flow and cam selection will be the same what ever route you take.
Not all 2002's came with LS6 blocks. The LS6 blocks appeared in roughly 10% of 2001 and 25% of 2002 LS1 powered F-bodies due to an overage of LS6 blocks. The blocks are interchangeable, as the LS1 F-bodies with LS6 block still had the LS1 heads.
there is no proof that the better bay to bay breathing even does anything.
If you follow the trend in the forsale sections of the .COM's and maybe even contact some of the major engine builders most will say the same thing, They even think the Ls1 Block is a stronger block 99+ to resleeve. Either one will do the same thing.
Guys,
thanks for all the responses, when it comes time to buy I'll stick with the LS1 and find out whether an ATI P1SC wil fit my engine bay.
If not, maybe an LS2 crate engine will be available by this summer ?
Thanks,
Marcel
Thanks,
Marcel
