found some procharger inlet goodies
Old Mar 14, 2010 | 04:43 PM
lmt0705's Avatar
Default found some procharger inlet goodies
found these at pep boys, one of them should be a nice start to a good inlet for my F1A. There 4in. diameter one is aluminum the other is rubber. ill be on the dyno next week so hopefully I can get some stock procharger hat vs. custom dyno numbers. not sure which one im going to use yet. the rubber one is pretty stiff so i dont think it would collapse
Old Mar 14, 2010 | 04:59 PM
blue00ZZleeper's Avatar
I'm pretty interested in this seeing as how I need to make a custom intake/hat for my D1 now and my F1 when I get her. Let me know how it goes.
Old Mar 14, 2010 | 11:19 PM
BJC51984's Avatar
I am using that same aluminum one on my D1SC right now, but had to make a lot of modifications to it to make it fit...the outlet on the Blower is closer to 3.75" than 4" so getting that elbow to stay clamped on was a big issue, and it also runs right into the lower radiator support because 90 degrees is not a tight enough bend, definitely makes for a good setup if you take your time and modify it though...good luck
Old Mar 14, 2010 | 11:23 PM
lmt0705's Avatar
wonder if i should try the silicone one then? its got a little bit tighter bend in it
Old Mar 15, 2010 | 12:39 AM
Frost's Avatar
I'd be weary from fear of collapse...
Old Mar 15, 2010 | 01:02 AM
lmt0705's Avatar
its pretty stiff but if people think it might be an issue ill make the aluminum one work. the silicone one looks a lot easier to make fit, especially since i can put it right on the blower
Old Mar 15, 2010 | 02:35 AM
dlandsvZ28's Avatar
What's the part number for the rubber one?
Old Mar 15, 2010 | 10:56 AM
LS1RedZ's Avatar
I cant wait for some results. Im thinking about making another intake hat for mine. Does anybody know where you can get the piping to make this intake hat below? It was made my SSmokin01. Hope he doesnt mind me posting this up.
https://ls1tech.com/forums/forced-in...alot-pics.html
Old Mar 15, 2010 | 04:47 PM
Jimmy P's Avatar
I bought the Pepboys 4" one and had it cut and welded again to make a extra tight bend in my setup. It works well.
Old Mar 18, 2010 | 02:18 PM
LS1RedZ's Avatar
Have u started messing with the elbow yet?
Old Mar 18, 2010 | 10:33 PM
lmt0705's Avatar
yeah just briefly though, Im going to have to move the radiator forward but ive got 2 cars in my shop for complete paint jobs and I have to pay the bills eventually so Ill start playing with it next week
Old Apr 16, 2010 | 01:10 PM
sschoeffler's Avatar
Any updates?
Old Apr 16, 2010 | 01:12 PM
NemeSS's Avatar
Old Apr 16, 2010 | 01:44 PM
AFASTYZFR1's Avatar
Have any pics?
Old Apr 17, 2010 | 12:04 PM
Well for what its worth folks, I went up to pep boys and they have a 90 degree hard rubber elbow that is 4"they also have a 4" coupler that has a small rubber ring that fits inside of it that makes it adapt to a 3.75. So I bought the 90 and the coupler, used the rubber ring inside the coupler for the 90 degree elbow, bought a 6" straight tube to go from the elbow to the K&N air filter. Everything test fit perfectly! My car is still in Claremore getting the intercooler piping tig welded up. So this next Friday it should be done I will post pics on how it looks. Should flow a HELL of alot better than the Procharger inlet hat. Looks alot better too! I think I spent about 50 bucks total not including the K&N
Old Apr 17, 2010 | 12:08 PM
Its not going to collapse, this stuff is TOUGH
Old Apr 17, 2010 | 06:24 PM
LS1RedZ's Avatar
DEFINITELY let us see some pics of this setup man. I really wanna get rid of this stock hat setup. I think I could get another 2 psi by switching to something better.
Old Apr 17, 2010 | 09:35 PM
SS LeadFoot's Avatar
I would like to see some pics also
Old Apr 18, 2010 | 12:13 PM
Another thing just dawned on me, I've got the Griffin stand up radiator but I'm also running the A/C Condenser and my radiator is at the lip on the lower core support so it hasn't moved back any. It should also work with those of you who have a stock radiator that slants.
Old Apr 18, 2010 | 09:08 PM
AFASTYZFR1's Avatar
Post pics of your inlet when you can! I loose 100 rwhp from my inlet hat and have back to back dyno pulls to show it....I am working on getting a decent inlet on it
https://ls1tech.com/forums/dynamomet...hp-645-tq.html
