Finally Got Dyno #'s With Maxed Out D1SC
#42
i gained around 30 RWHP on the dyno by rem the inlet-i use an F body one on my chevelle, with a vette Procharger setup-went to Home Depot and got a small roll of 1/4" screen, just molded it around the opening, and used a hose clamp to secure it-i thought the small screen would be a rest, if you added up all the surface area of the screen-when i make a pass i'll stick it on
i would like to make a larger 4" inlet deal, gotta work on that
nice #'s, better than my stroker w/AFR 225 heads, lol
#47
I wish I would have seen this thread before you went to the track. I would have told you to remove that screen from the inlet. They are huge restirctions actually.
Even the smallest K&N made will flow (and protect) better than any screen will offer.
If you're going to run with it anyways, at least open up the surface area to allow more airflow...
#48
#50
On my car I was aiming for 16psi with my F1A. I had a custom inlet fabricated turned out to be about as good as the stock procharger hat 13 psi was all it was good for with an F1A! I finally got the procharger truck inlet to work with my FMIC setup and so far so good making 16-17psi on a 418CI.
I highly suggest the truck inlet and that huge cone K&N air filter it will meet your flow requirements and won't break the bank. It's pretty much the only thing that will fit behind the stock radiator. Make sure you verify it will fit on the D1 head unit though.
I thought I was going to play that game where you take the inlet off for the track but with these cars it's a PITA you got to get underneath the damn thing to remove the air filters. Just removing that thing through my tune for a loop so much that it was unsafe. I suggest biting the bullet finding a good inlet and sticking to it. I know you said track only BUT fine dust will wear away at the impeller blades making them rough and ineffective. One rock will ruin your day too.
#51
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#54
Do you have anypictures of your setup?
#58
