02 Sensor placement....
Is it best to locate them on the turbo downpipe? If so, how far down the pipe is best?
I've been looking around a bit for pics here, but have not had much luck yet.
That's exactly what I thought...and it makes sense. But, I've also been told that the extra heat produced by adding a turbo will destroy an O2 if it's placed too far upstream. Is this total mis-information?
Anyone else have any thoughts from real-world/ personal experience?
I'd love to be able to put them right at the collectors, before the merge... but if I can't, my only other option is to place them on the downpipe across from each other.
Off topic, but do you really need the o2`s when going FI and sd tune? When im only using the wb o2 to tune?
On topic, I would also like to know where people have theire NB o2`s! In one of our turbo ls1 nissans we have them just after the manifold "log"
Stock location means nothing when you are increasing egt's by a BUNCH due to the turbo increasing the engine's output....and the turbo is hot BECAUSE of the much-hotter exhaust that is feeding into it?? Don't get me wrong, cuz I'm not trying to sound shitty here...and I'm most certainly not un-appreciative of your comments. It just appears that you might be (if I'm reading your replies correctly) saying that the turbo is hotter than the exhaust gasses that are up-stream.....which does not make sense to me.
I was just thinking that maybe the manifolds were better at dissipating the heat, since it is half of the volume that the turbo sees...but that the egt's were higher up-stream of the turbo?
Bottom line is that I've heard rumors of people wasting o2s in a rapid fashion when up-stream of the turbo, and I'm not sure if it's true or not. I just don't want to make a poor choice on where I locate mine. Anyone else have issues running them near the exhaust collector??
