Modular Turbo TWIN TURBO KIT!
#243
did something get edited out?
Also aren't Precision e comp covers the same exterior dimensions all the way up to 76mm? Aren't 7675's the same size as 6765's? Why does the turbo options for precision end at 71mm?
#244
I think the E cover is a 3" inlet and 2" outlet.
The 3" inlet would limit it to the 71mm.
The S cover is the next one up the ladder
and it has a 4" inlet and a 2 1/2 outlet.
There's enough room in this one for the 76mm wheel.
#246
Here are some pic's of the A/W water tank.
I'll point out some of the features.
1: It's a T&B water tight strain relief.
This keeps the wiring connections out of the tank.
2: Industrial garden hose style fittings on the return hose.
This is there so you can hook a piece garden hose to the return
and drain the tank using the pump.
3: Rule 2000 pump mounted on a stand in the tank.
This will help keep the pump from sucking trash off the bottom.
4: Tank is made of marine grade 5052 aluminum.
More corrosion resistant than 6061.
5:There will be a manual pump "ON" bottom mounted
next to the tank to run the pump to drain the tank when needed.
"Not yet mounted".
"Not yet mounted".
#249
Hopefully by tax season.
I hate to set a date, we have set very high standards for this kit and we don’t want to leave any stone unturned.
We’re currently looking for a good location for the coolant recovery tank, the passenger side air filter will need that space. We have some ideas but need to weigh the pros and cons.
#250
whats goin on with your wbsite? cant get in, does funky stuff. jus tryin to check your products and what not. also anxious for this kit to finish and see what it looks like. from the looks of it, resembles aps kit, but with ur own special additions?
#251
http://www.sophos.com/security/analy...malpdfjsp.html
#253
My site got hacked, I’m working on it.
Resembles? Look a little closer, this kit will
make the APS kit look like something from Walmart.
It’s been going on for a long time I agree, but doing it right takes time.
There are tons of things that we wouldn’t settle for ...
So we would work on other parts until a better solution come to mind.
Sorry it’s taking so long guys.
If it was a one off kit for one car it would had been finished over months ago
but it has to fit your car and his car and there cars.
It’s not easy.
It’s not easy.
#254
Coal Mining Director
Here's a tip for ya. Put water in the IC tank, run a hose up to the front of the car, through an IC and back to the rear of the car but don't attach it to the tank...put it in a 5 gallon bucket...turn on the Rule 2000 and time how long it takes to fill the bucket.
Repeat with a Rule 3700.
Be sure to use the actual hose size that will be used in the installation as the Rule is VERY sensitive.
You'll be surprised at the results.
#255
#256
Any updates Rob or Chris? Getting married next year so my money is dwindling.
#257
It’s not easy.
It’s not easy.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
