Bypass Valve, how to save cash?
Help me out here. I need to learn more about this after searching a bazillion posts.
Going from a P1SC with twin 3.5" IC's to a D1 with 4" FMIC. I've got everything together for my build ..... but the BPV.
What is wrong with keeping the small black Procharger PBV instead of dropping serious $$$ for a "race" or "mondo" BPV? Does the small one not relieve enough pressure and damage the impeller? Has this actually ever happened to anyone here?
By the way, I'm not going to recirculate from the BPV. Vent to atmosphere unless too loud (then feed back to blower)
What is the least expensive route that won't cause damage?
So nobody ever damaged a blower with too small a BPV? Are the bigger BPV just a marketing ploy to get more money?
I'd really like to save $300 on this build, why haven't others?
Serious or are you f'n with me? I was considering keeping the small procharger BPV and adding a BOV. Wouldn't a blow off valve act faster to purge any "surge" when the throttle is closed? Does a BPV take longer to react with signal line to manifold vacuum compared to a BOV?
Can BOV's be set to open at 3psi over max boost at WOT? This would protect things from going boom when the throttle slams shut at 7K RPM, right? Then at normal cruise, say 2-3K RPM, the BPV is open (BOV closed) and the throttle is seeing less pressure.
Whats a good BOV, and how do you adjust them?
You can really slow down the impeller with the back pressure from an insufficient BPV. I had a TiAL BOV in mine with a 6psi spring. It was half open at idle, and fluttered under part throttle, then obviously shut under boost. It worked perfect, and is half the price of a ProCharger BPV.
