How much horsepower can you make with a TC76?
What is the horsepower potential of a TC76 with a .96 turbine housing? I emailed Turbonetics and they said 700 crank horsepower because of the small compressor housing. This doesn't sound right, isn't a TC76 capable of 900-950 crank horsepower?
i just got my setup done, ls6 heads, fast 90 intake, forged ls1, 10:1 compression, t56 built, 12 bolt w/3.42 with tc76. running 12lbs, don't even know what it will make nor have I put enough miles on it to dyno....still breaking in.
Should give much better top end, I had a .96 on my 383 and it would fall over around 5k rpm, went to a 1.32 ar, spools dam ne'er as fast and pulls hard to the limiter 6700 rpm.
