Need larger turbo?
TC76 .96A/R
Motor only builds 11-12lbs boost, is the TC76 out of breathe? On my LS1 with ported heads it built 14+lbs of boost.
spools fine just tops out at 11-12lbs. Took all the cold side piping and intercooler apart to check for leaks.
If you are worried about the back pressure opening the gate just put the reference to the gate on the top port only. That will give you max boost the turbo can supply and insure the gate is not opening. Just make sure you keep a close eye on it in case it does make more boost.
But the 76 is probably small for the 383. I'm going to be running a TC-78 on a 370 and will probably be maxing it out.
Did you change springs or anything in the wastegate?
73 degree iat
5100rpm
83% tps
64lbs/min maf reading
65% injector duty on 60lb'ers (69@58 psi)
10.5afr W/100% methanol injection.
no knock retard
"The Hurricane units are essentially exteremely large compressors in smaller housings. That compressor housing limits what is normally an 860 CHP compressor wheel to about 700 CHP. It's mean for vehicles that need to stuff a compresor that large into almost no room."
I'm not sure what to think, I've seen people get more but when talking with Robert he made it sound like what I'm seeing is normal. He said a 383 with ported heads&cam is to much motor for a TC76, he thought my backpressure should be pretty high.
