fast 102
Old Jun 15, 2010 | 07:03 AM
slowc6's Avatar
Default fast 102
Hi I just purchased a aps twin Turbo kit for my stock ls2 c6. I also have a fast 102 and Nick Williams throttle body lying around. My question is would I see any power increase or should I sell it and use the money else where. Thanks
Old Jun 15, 2010 | 07:37 AM
smokinHawk's Avatar
id sell it before it cracks under boost, but thats just me
Old Jun 15, 2010 | 07:53 AM
slowc6's Avatar
Well its not on the car yet still in the box was gonna go N/A but got a good deal on the Turbo kit.
Old Jun 15, 2010 | 04:33 PM
355TurboLT1's Avatar
Have you ever seen or owned a FAST 102 that cracked under boost? I bet you have not as fast has tested them to 60psi. The old FAST manifolds had problems but nobody as of yet has had a 102 crack. Lets stick to the facts and not trash a great manifold.
And to the OP if you have to offload the 102 PM me. I plan to run one on my ERL LS2 with close to 30lbs boost. Should be a good test!
Old Jun 16, 2010 | 05:55 AM
smokinHawk's Avatar
Facts?
I have seen a lot of guys with boost crack them
that is enough facts for me. Plus in a boosted application it isn't worth the high price tag. Get a single plane if you want somethiing different then an ls6 manifold
Is the op willing to gamble with that kind of money?
Old Jun 16, 2010 | 06:23 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Absolutely correct. If you want a factory style intake, a LS6 is more than good enough.
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
At the old shop we swapped out an LS2 intake for a FAST 92 and lost 2 psi of boost, but went up in horsepower, from 809 to 864 rwhp. Here is a link to the car. http://www.exoticperformanceplus.com...Car.php?car=29 Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Jun 16, 2010 | 09:52 AM
So you have seen all these fast 102 intakes break huh? I have heard of none just the old ones. The ls6 is prone to break at high boost as well. People love it cause its 1/4 the price of the fast. The old intakes did as I mentioned crack quite often
Old Jun 16, 2010 | 11:36 AM
slowc6's Avatar
So how much would I gain on a stock ls2 with a aps kit with the 102 setup vs keeping the ls2 TB and manifold.
Old Jun 16, 2010 | 02:02 PM
Facts?
Just to clarify, we are talking about the FAST LSXR 102 not the 92. I think you are confused. But if not I would love to see pics of some cracked 102's that you claim to be seeing. Again these are tested to 60psi so a low 20psi bump isnt going to do **** to the manifold. Now a backfire or improper install you bet.
Old Jun 17, 2010 | 09:54 PM
So.jerZ-28's Avatar
Cracked intakes are normally from improper installation (torquing of manifold)
never seen a 102 crack and if it did I'm sure it was due to some other malfunction such as stated above or backfire,impeller deciding to take a ride through the airflow highway , etc....
Old Jun 17, 2010 | 11:19 PM
one fast zo6's Avatar
sell the fast 102, you WILL need the money to go turbo. under boost the ls2
intake will work fine. IMO
Old Jun 18, 2010 | 12:06 AM
reamo04's Avatar
Just throwing this out there, but the old ones were tested to high PSI as well. The issue isn't just pressure, its also heat. Have I seen a 102 crack? no. Have I seen 90s and 92s crack? Yes. I am witholding judgement on the 102 until more and more people have run them to see if they crack or not. Am I going to gamble a grand to find out? Nope, thats why I run a vic. jr.
Old Jun 18, 2010 | 12:29 AM
So.jerZ-28's Avatar
I would stick w/ an ls6 intake, reason being that the ls2 intake is made out of a different material I believe,
but biggest reason that if you look into the intake ports of the intake you will see where the intake is sectioned together.
In that area it is not fused together/glued etc... I'd be worried about that cracking/coming apart under high psi.
yes ls2 has 90mm opening, if you need that, run a l76/l92/ls3 style intake than.
you can pickup a take off unit from SLP for like $275.00
Old Jun 18, 2010 | 01:52 AM
Ok now we are on the same page. Until we see a 102 crack it is too soon to pass judgement. That is all i'm saying. As far as the design goes the 102 is quite a bit different than the 90/92 as the 102's runners can be removed to be ported and such. I mean the in perfect world I would run a Wilson intake but i am not an M.D. so I can merely dream about how nice it would be to have a $3,000 intake. lol.
Old Jun 18, 2010 | 06:32 AM
slowc6's Avatar
I would. R
I would run a ls3 manifold but then ill have to run ls3/l92 heads so that wouldn't save me any money.
Old Jun 18, 2010 | 07:06 AM
So.jerZ-28's Avatar
Originally Posted by slowc6
I would. R
ahhhh.... the hell with saving money.
fast 102 intake..... automatically though ls3 heads, sorry, I got a set of p&p'd l92 heads on mine with the 102 intake.
Old Jun 19, 2010 | 04:40 PM
MY99TAWS6's Avatar
Running fast 90 but so far haven't turned up the boost from 7.5psi with standard aps turbos the lg are not installed yet. Should be installing them soon and will be taking boost up see how the 90 does.
Few things might be reasons for cracking. One you have to use proper valley bolts. Some guys just throw on used intake without the proper lower profile bolts.
also its inch pounds some guys torque **** out of these intakes.
I also tapped and screwed fitting where old map went the 90s had terrible map retention setup. And put rtv between shells. I can see an backfire in the intake cracking it maybe.
I have burst valves in mine and have also heard of them blowing prematurely. I am not sure if plan to run burst when go to a 102 but yeah unless see bunch of actual video evidence of cracked up 102s being going to one of these next season most likely.
Old Jun 19, 2010 | 05:44 PM
98Z28CobraKiller's Avatar
Restricted User
I've put 20 psi to my glued together Fast90 so far without issue.
Old Aug 21, 2010 | 04:27 PM
Big_Bird_WS6's Avatar
you guys have all these negaitives towards the afst 102. but people like Tony M from AFR says it will hold the boost fine compared to the old models.
