Low rwhp on twin turbo setup
Also what kind of valve springs do you have? Maybe also switch back to stock rockers since the yella terras might be causing some valve float due to marginal springs, high exhaust backpressures, etc.
GT35s should be able to do like 1400 engine hp .
What about trans and converter..Is this a triple disc converter..? Are you locking it on the dyno? single disc pretty sure would simply fry. What trans..Maybe trans is not holding the power.
What about knock retard..did you see huge knock retard?
What about fuel up top.What are you running for injectors, pumps..?
I can't see that cam being much of limiting factor. And with FI the heads and intake don't matter hugely either just mostly give you more power at lower boost.
Up the boost a few lbs. I bet the power will jump nicely.
