New build/combo..F1/370 Dyno Vids/results MORE BOOST!
#63
M6 car? and what was the base fuel pressure? im pushing on my 60s now. ive seen 108% and thats at 14psi and 11.2 afr .but im runnig a 4l80 so if you made 780wheel my car should be near 680wheel. any track times?
#65
LS1Tech Sponsor
The cog bracket is a little different and yes I did come to a semi-conclusion lol. I spoke to a welder at work (30+ years) and needless to say hes an expert. He said theres a special rod to use and the block needs to be very clean. He also said to pre-heat the block to keep the expansion to a minimal when the welding starts. I just need to convince him to do the work for some $$$. I'm going to have the machinists cut a piece of plate steel probably 1/8th" thick and weld it in. Hopefully it works. I then want to take a deep nut and weld it onto the plate to thread both the top alt. only bolt and the top j-bracket. That'll give me 4 places of contact and should stop most of the bracket flex....2 just wasn't gonna cut it and if I can go 4 over 3 why not?
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
#66
Yeah M6 car. I think I have it set at 62 on the regulator. Took it to the track Saturday night. It was loving the cold air to much. AFR was in the high 12:7-13:0 range and I cant add fuel cause im pushing on my injectors already. Freakin sucks cause the DA was like 100. Ran a 6.74 @ 101 in the 1/8 and cut a 1.47 60' on my second pass and this is on a new tune (not even using my 2 step either). Its an alright time considering I was making waffles during my shifts. Car should run alot quicker once I get it dialed in and tweak the tune at the track. I wanna go auto bad to see what she'll really run.
#68
LS1redZ, which track did you go to? They still have that one local in Waco, or did you have to go out to Ennis or something? I lived in Waco many years back. Only track Ive seen so far that would let people run with spare tires for skinnies up front and not care. What tech inspection? lol
#69
#71
Bump. I had a buddy at work weld that plate on that I was talking about. I dont think I've been that nervous in awhile lol. It did come out awesome. I need to grind the welds down a little bit to smooth them over and she'll be ready. I'll post pictures as soon as their done loading. Also, trust I have some viper pics from sema you should look at. I'll post them up in here or in your thread.
#75
I was going to say the same thing. Me and Blackrifle have the Magnafuel FPR. We both like it alot. And yeah, I would probably go with some 80#er's. I got 60#'s to my dismay. Going to have to swap them out, especially If I want to do this E85 idea. Which i REALLY want to.
