I suppose its time to make a build thread...truck manifolds!
#141
A local has some push rods that should work, so Ill be picking those up and tossing em in. Im a bit worried because these Lunati Golds seem a bit high and Im hoping they rockers will fit under the valve covers without a spacer....
Once I find a tubing cutter I can finish up the ABS delete and linelock, then I can throw my wheels on. Getting pretty excited.
#144
Ive been pretty lazy on this whole project. Now Im stuck at getting the brake lines flared for my ABS delete kit. The tool SJM sent me sucked and I ended up breaking the wingnut trying to tighten the brake line enough to keep the line from moving.
#146
Thats possible. My friend offered to come over and do em for me so Im just waiting to see if he will pull through. Im working on wiring and some other stuff in the mean time, no biggie.
#151
Upgraded oil feed to -4 and added an oil pressure sensor
![](http://i31.photobucket.com/albums/c361/TruStinger/New%20Build/IMG_20110605_153019.jpg)
Added fuel pressor sensor
![](http://i31.photobucket.com/albums/c361/TruStinger/New%20Build/IMG_20110605_154020.jpg)
Pulled out the pressed in fittings on the water pump, time to get the holes tapped
![](http://i31.photobucket.com/albums/c361/TruStinger/New%20Build/IMG_20110605_163604.jpg)
Trying to retain the stealth look by making the intercooler black
![](http://i31.photobucket.com/albums/c361/TruStinger/New%20Build/IMG_20110605_175217.jpg)
Finally painted the bumper I built, matches the engine bay and intercooler
![](http://i31.photobucket.com/albums/c361/TruStinger/New%20Build/IMG_20110605_182506.jpg)
End result
![](http://i31.photobucket.com/albums/c361/TruStinger/New%20Build/IMG_20110605_183137.jpg)
![](http://i31.photobucket.com/albums/c361/TruStinger/New%20Build/IMG_20110605_183157.jpg)
Painted the strut tower brace, then realized it was a brighter red than I put on the TB and intake manifold. I like this color more though..
![](http://i31.photobucket.com/albums/c361/TruStinger/New%20Build/IMG_20110605_200925.jpg)
End result
![](http://i31.photobucket.com/albums/c361/TruStinger/New%20Build/IMG_20110605_202249.jpg)
#154
Wish I had a beach to go to lol
Decided to keep the STB the same color and paint the TB to match. Ill just paint the intake manifold flat black like everything else and call it good. It was too much of a pain in the *** to mask and paint the way I did before.
#159
Finally have electricity working in the car. Just need to run grounds from the head to the block, and the block to the chassis.
Time to start some reassembly.
