Piston Oil Squirters
Old 10-28-2010, 09:29 AM
TT402LS1's Avatar
Question Piston Oil Squirters
Anyone here done piston oil squirters on their engine? What mods are need? Pics???
Thanks - Ron
Old 10-28-2010, 10:11 AM
7 Second Club
Phil99vette's Avatar
Most of the high HP import guys I know take the oil squirters out for street and strip.
Old 10-28-2010, 10:13 AM
speedracer5532's Avatar
I am running Piston Squirters from Katech. You have to machine the block for them.
Attached Thumbnails Piston Oil Squirters-imag0002.jpg   Piston Oil Squirters-imag0004.jpg
The following users liked this post:
Homer_Simpson (01-18-2022)
Old 10-28-2010, 10:48 AM
TT402LS1's Avatar
Whats the price on those? And what lind of machine work needs to be done??
Old 10-28-2010, 10:54 AM
http://store.katechengines.com/pisto...rters-p74.aspx
Old 10-28-2010, 11:12 AM
TT402LS1's Avatar
I would assume thats each? Im running a LQ4 block. I called and left a message with Jason at Katech. I was wondering if I could run these on my motor??
Old 10-28-2010, 11:46 AM
Restricted User
98Z28CobraKiller's Avatar
Why??
Old 10-28-2010, 11:52 AM
Yes that is each and no I don't think it will work on the LQ4 or LS1 block. LS2, LS3, LS7, and LSX I know it will work on.
Blac94z28 (11-11-2019)
Old 10-28-2010, 05:12 PM
lazylongboarder's Avatar
Seems like it'd be beneficial in a RR application or Mile. Wash away heat gathered from sustained load. I dig.
Old 10-28-2010, 05:29 PM
427's Avatar
The pad is not in the LQ4 block for the factory type oilers. I use one that goes in the main bulkhead in high power drag engines, but it leaves the galley open and will cause the galley to drain when sitting. Not sure if that would be a problem in a daily driver.
Kurt
Old 10-28-2010, 06:04 PM
TT402LS1's Avatar
Kurt
bulkhead? Got pics??
Old 10-28-2010, 06:16 PM
427's Avatar
Looks like this.
Kurt
Old 10-28-2010, 06:40 PM
TT402LS1's Avatar
If those are pointing up how will it cause the galley to drain? Is this mod best for drag apps?? Is this mod worth it on a street car? Im leaning towards not running an IC,(no room up front) and releying on Meth/water inj.for cooling.
Old 10-28-2010, 08:37 PM
TT350's Avatar
Check my sig. Not a LSX but lots of info and pic's.
Old 10-28-2010, 09:36 PM
427's Avatar
I use it in boosted engines mostly for cooling the pistons, but I have used it in one NA engine for land speed racing. Nascar uses them with multiple nozzles on each piston to keep the crown cool.
The nozzle is below the main oil galley, this may cause draining of the galley when the car sits around.
Kurt
Old 10-29-2010, 06:38 AM
chuntington101's Avatar
Kurt
I think i read somewhere the F1 cars use about 10per cylinder to keep piston temps down.
Chris.
Old 10-29-2010, 09:15 AM
427's Avatar
More nozzles spraying a finer mist would be better, but the real estate is just not available in these engines. Comp has a nice design in the RHS block, but the nozzle is still in development right now.
Kurt
Chris.
Old 10-29-2010, 01:58 PM
pdasterly's Avatar
Had them and sold them
Old 10-30-2010, 02:46 PM
stevieturbo's Avatar
Why would they be so stupid as to do that ?
I read ages ago a guy who does OE research for Mahle, and he was saying the oil jets can offer massive piston cooling and improvements to detonation resistance.
If an engine came with them fitted, it would be mental to remove them.
54inches (03-15-2024)
Old 09-25-2011, 03:50 PM
Looks like this.
Kurt
Can all 8 be drilled like that ? What sort of nozzle size ?
Quick Reply: Piston Oil Squirters
