Introducing the Aster Auto Spring Loaded Tensioner Bracket at Brute Speed!
#82
I know, it left me wiped out! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
#83
Four more to sell at the reduced price! Bob
__________________
#84
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
My dear friend Bob!!
I really wish you the very best with this new product!! Which I am sure will be sold really well, because it is really nice option when you thing about upgrading the horrible stock J bracket pulley configuration (belt slipping).
I will look forward to get one of those Aster brackets!! By now, the bank account is a bit out of shape hehe!!
The best for you Bob!!![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Rodolfo Lara Pohlenz
#87
__________________
#88
Four more to go for this group purchase, the first four will receive them as soon as they are built. Anyone who wants to save fifty dollars, get in on this group purchase! Bob
__________________
#89
Customer list updated on group purchase. Three to go! Bob
__________________
#90
Customer list updated again on group purchase. Two to go! Bob
__________________
#92
Yes indeed, they are going out in the next couple of days! Thanks for being patient.
Bob
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
__________________
#93
Two left at the reduced price. Mike, are you ready?
__________________
#94
That's a pretty good question. I think most of its advantage is the 99% more belt wrap and the ability to "adjust" to a belt growing a touch. I wonder which spring tensioner they use? I like asters setup because its been proven multiple times and more so because it doesn't require special tools. If I break a belt at the track or something I can change it out with ease. It also allows you to run the 7.65 ATI crank pulley as the SDCE you can't run more then a 7.25 SDCE pulley. Aster have you been able to run some numbers for belt sizes for us guys with the 7.25 crank pulley?
#95
Two more left on the group purchase! Bob
__________________
#96
Bob added a belt matrix to the bottom of the product page on his website for the standard 7.625" crank pulley with various HU pulley sizes listed. However, the alignment on the webpage is currently off. For some reason the tabs are different so the sizes that should be for a center idler position are listed under far and the far sizes are off to the right. I have repeated the matrix below, anything with a ? is unconfirmed and best estimate based on pulley sizes compared to known ones.
Code:
HU Pulley Idler position Diameter Close center Far 3.25 50.5 3.4 50.5 3.55 51? 51.5? 3.7 51.5? 52.5? 3.85 52.5 3.9 52.5? 52.5? 4 52.5 53? 4.13 53? 4.25 53.5? 4.38 53.5? 53.5? 4.5 53.5 54? 4.63 54? 54.5? 4.75 54.5? 54.5? 5 55? 5.25 56?
#97
Just installed installed this bracket. The direction were easy to follow, fitment was perfect.
There is a lot more belt wrap around the pulleys, say goodbye to belt slip. Using a 7.65 and 3.55 pulley I needed a 51.5" belt. I installed the idler pulley in the center hole, this gave the belt the most tension without going to far. I would highly recommend this setup to anyone, even running low boost. This bracket helps take pressure off the bearings in the procharger by using spring loaded tensioner. Thanks for a great product Bob and Chris.
Jason
Jason
#98
There is a lot more belt wrap around the pulleys, say goodbye to belt slip. Using a 7.65 and 3.55 pulley I needed a 51.5" belt. I installed the idler pulley farthest from the procharger, this gave the belt the most tension. I would highly recommend this setup to anyone, even running low boost. This bracket helps take pressure off the bearings in the procharger by using spring loaded tensioner. Thanks for a great product Bob and Chris.
Jason
Jason
Chris, thanks for the heads up on the alignment on the matrix chart. I hadn't noticed it.
Thanks! Bob
__________________
#99
I've been playing around with the matrix chart, I could not get it to align after I had imported it. It would look just fine until viewed "live", so I redid the chart. I'm still not 100% pleased with it, I'll probably add question marks to it where there are no numbers, so it will be easier to read. Bob
__________________
#100
Bob and Aster,
I am interested in this product if it improves the "rattle" sound that some complain about with the stock bracket. If I spend as much as I am about to on the system, call me a ricer if you want but I want it to sound as good as it goes. I know the SDCE almost eliminates this rattle sound. Does this bracket improve or fix this sound?
The second reason and really the most important is I want to reduce the pressure on the crank. By using this bracket since it has a tensioner does that mean there will be less tension on the crank/bearings compared to a standard set up that always has a lot of pressure on the crank?
