BEst cam choice for my forged ls2 d1 procharged
Im building an ls2 d1 procharged 3.4 pulley intercooled. wiseco -11cc pistons , callies rods, stock stroke. super vic intake and elbow ,90mm tb, ported 317 heads. i have 60lb injectors but i heard i might need something more like 85lb ones and this is the cam that was recommended to me 224/228 .581/.588 114 LSA. Would any of you recommend anything different thanks
well i had the 243 head i was goin to put on it. but people acted like i needed lower compression... what kinda boost will the D1 procharger be pushing with the 3.4 pulley
I would get 80's from the get go. You should be in the 16-18psi range with that pulley. I have a -12cc dished piston with a 243 head on my 370. Target compression is 9.5:1. I also think your leaving a little on the table with your cam. It'll work for sure but I'd go with something more in the 232/236 range on a 114/115 lsa. I have a pretty aggressive cam for my new combo.
