which heards for 5.3 turbo
Old Feb 12, 2011 | 09:12 PM
LQ4 S10's Avatar
Default which heards for 5.3 turbo
i can get a pair of 317s for $100 or should i just leave the 862s on. this is a low budget project just done know if they would help or not. i have read some that say to run them and some say stay with stock heads. so should i swap them or just leave them alone and use money for other things needed
Old Feb 13, 2011 | 12:26 AM
tripblackls1's Avatar
if your heads are still on i would say leave them
it should be 9to1 comp with stock heads with 317s you would be about 8to1 comp and unless you plan on more then 16psi then its not going to benefit you
Old Feb 13, 2011 | 12:58 AM
cjmatt's Avatar
862s is 9.5:1
317s is 8.7:1
just FYI
If you want to run 10+ psi, Id run the 317s. You'll pick up power as they flow more too
Old Feb 13, 2011 | 02:56 AM
edit nvm, i got them mixed up with 4.8 lol
Old Feb 13, 2011 | 09:18 AM
BahN's Avatar
Get the 317's.
Old Feb 13, 2011 | 09:51 AM
NemeSS's Avatar
Use the $ somewhere else. Stock scr is 9.4:1 as is.
If u pull heads. The 317s will need a slight mill for a flat surface. New head gaskets and if possible use of studs. Or just leave motor as is and spend on tune and fuel system. If anything get upgraded valvesprings and pushrods for the motor. Should have no prob running up to 10psig on pump gas with adequate fuel supply and correct calibration and fmic
Old Feb 13, 2011 | 10:04 AM
LQ4 S10's Avatar
looking to get 500rwhp maybe a lil more. never done a turbo gas engine so not sure on alot of things been reading getting some info so anything you can help me with will be appreciated also im running mp t70 turbo, built th350 trans, not sure on gears yet but will be in 71 C10 lwb
Old Feb 13, 2011 | 10:06 AM
LQ4 S10's Avatar
also would ls6 valve springs be good budget upgrade
Old Feb 13, 2011 | 03:14 PM
skinnies's Avatar
Just leave the stock heads on it, no reason to change them out IMO. You can make 600 plus on the stock heads just fine with the right turbo.
