80mm + 365ci + 22lbs
Old Feb 20, 2011 | 10:35 AM
turbo370supra's Avatar
Default 80mm + 365ci + 22lbs
Looking for hp ideas of this combo
Borgwarner 87mm turbine 1.25 ar t4. 80mm compressor with race cover.
9 to 1 compression. 225 cnc heads. 23x cam. Ls6 manifold.
Dudeman has all most same turbo on 16lbs made 750 wheel threw a th400.
Ninetres had the same turbo as dudeman with the 83mm turbine. And with 18lbs went 9.29 @ 153 at 3550
What power do you all think 22lbs will make
Old Feb 20, 2011 | 10:56 AM
TurboAv's Avatar
Why T4?
Old Feb 20, 2011 | 11:08 AM
Because that's what I all ready bought
Old Feb 20, 2011 | 11:13 AM
TurboAv's Avatar
Lol. Just run it then and tell us how it does.
Old Feb 20, 2011 | 12:23 PM
SPRAYED 01's Avatar
fly wheel hp could be around 1100. Not sure what you would put to the ground. Depends on drive train
Old Feb 20, 2011 | 09:28 PM
westtexasbuff's Avatar
Prolly round 850 - 900.
Old Feb 21, 2011 | 09:50 AM
venom ws7's Avatar
What transmission and rearend do you have?
I hope I can get close to 1000rwhp with 20psi and race gas if the poor 347ci can hold that will be enough for 150mph and mid 9s
after that 400+ci and 91mm
Old Feb 21, 2011 | 09:54 AM
02_ramair_ta's Avatar
Id like to see how this handles the 22psi..
What heads do you have? LQ block? Are you going to ring it?
Old Feb 21, 2011 | 10:21 AM
hellbents10's Avatar
LS1Tech Sponsor
I will guess 850-875 to the tire depending on the converter, could be close to 900 with a tight converter.
