High HP on Stock ECU
Old Mar 6, 2011 | 11:33 PM
dreamls1's Avatar
Default High HP on Stock ECU
Anyone running high HP on the stock computer? 1200+? Could it handle 2000hp with the right injectors?
Old Mar 7, 2011 | 08:58 AM
CAMSTER's Avatar
I do bilieve you can...
Old Mar 7, 2011 | 12:15 PM
dreamls1's Avatar
I am thinking of going stock computer, FIC Bosch 2200cc injectors and an AMS 1000. 2000hp on E85
Old Mar 7, 2011 | 12:35 PM
corpserodeo666's Avatar
I would run a better a different pump for that much power. I honestly think the A1000 will be maxed out at just under or slightly over 1k.
Old Mar 7, 2011 | 12:42 PM
KissMySSo1's Avatar
I think he's referring to the boost controller AMS1000.
however if he means an A1000 fuel pump; on e85 it prob wouldn't even support 600rwhp.
Old Mar 7, 2011 | 12:48 PM
Worm Boy's Avatar
We have made 1500rwhp on RC twin turbo corvette at 24lbs of boost. Stock computer is limiting us as this boost level.
Old Mar 7, 2011 | 12:49 PM
black98ws6ta's Avatar
There is no reason you cant make 2000 hp on the stock pcm unless the engine needed more then 30 psi to do it or you ran out of ignition.
I dont think the 2000's will support 2000 hp on e85 unless you are running them with a ton of pressure. The stock computer is just giving up a few features like WOT closed loop, built in limiters/2-3 step, ect.
Old Mar 7, 2011 | 12:53 PM
98Z28CobraKiller's Avatar
Restricted User
Can you? Yes. Should you? No.
 Michael S. Palmer
Old Mar 7, 2011 | 01:01 PM
I mis-read that. Yeah the AMS 1000 would be fine. But now I'm thinking of what fuel pump you will be running on this setup. And on a Stock ECU you should be fine reaching those power levels but I would say it is not an ideal setup. If you are going all the way than I would consider a BS3, or the Dominator by Holley, etc... Unless you are trying to go for some kind of record.
Old Mar 7, 2011 | 01:22 PM
dreamls1's Avatar
What is the limiting factor? Why only 1500Hp?
Old Mar 7, 2011 | 01:25 PM
dreamls1's Avatar
I will be running a Weldon belt drive pump. Plenty of pressure
Old Mar 7, 2011 | 04:58 PM
6techniques's Avatar
This is something I would like to see... I personally wouldn't do it. 2k+ hp is definitely BS3/FAST territory imo. I couldn't see myself dropping that kind of coin on a high hp setup to only use the factory controller.
Old Mar 7, 2011 | 05:17 PM
koolrayz's Avatar
Im not into the dyno scene but I have been over 166 mph with a 3750# car on E-98.
Could go faster with some more fuel and or gear. Belt drive pump and some of the 225 atomizers and you will fly
Old Mar 7, 2011 | 06:00 PM
Have you tried e-85 in the car?
Old Mar 7, 2011 | 08:24 PM
dreamls1's Avatar
No one is giving me reasons not to use the stock computer. I just don't see why it won't work if you can control the injectors.
Old Mar 7, 2011 | 08:25 PM
dreamls1's Avatar
As long as I'm running 7s I don't care how much Hp
Old Mar 7, 2011 | 10:53 PM
madmax4499's Avatar
is DFI an option? i dont see any talk about it on here
Old Mar 8, 2011 | 07:57 PM
dreamls1's Avatar
No input? Why won't the stock computer work?
Old Mar 9, 2011 | 04:51 PM
camarols1's Avatar
You actually received some good input from some of the front runners.
That type of power CAN be made with a stock ECU, but you will not have closed loop
fuel control, or individual cylinder fuel/spark control that an aftermarket system would allow. Both are a good idea at this power.
Also, since the stock ECU will only allow a certain amount of boost, the limiting factor becomes how much kpa is allowed by the ECU and the o/s loaded into it.
So basically, it becomes a race. (pun intended....)
If you can make enough power to go 7's at a lower boost level that can be controlled by the stock ecu, let's say 3bar, then you win.
If you have a newer ecu in which the o/s is limiting your max boost, like 24psi on Worm Boy's example, causing you to fall short on power, then you lose and must upgrade to a stock ecu that allows more boost, or go to an aftermarket system.
Going 7's is a bit out of my league, but I would have to presume that you can achieve your goal with an efficient combo and/or lighter car.
Jim
Old Mar 9, 2011 | 09:25 PM
dreamls1's Avatar
Jim
Jim, thanks for the input. Thanks that I was looking to hear. That help thanks
