View Poll Results: E98... Intercooler?
Yes
8
57.14%
NO
6
42.86%
Voters: 14. You may not vote on this poll
High HP, E98.... Intercooler???
Old Mar 10, 2011 | 11:50 AM
dreamls1's Avatar
Default High HP, E98.... Intercooler???
1500+hp do i need an inercooler with E98? Would Air to Air work?
Old Mar 10, 2011 | 12:16 PM
93formto98T/A's Avatar
There will always be major gains to be had with intercooling on any high boost setup. A2W>A2A. The colder and denser the charge, the more power you can make. I'm running e85 and a big A2W.
Old Mar 10, 2011 | 12:47 PM
lafinrat's Avatar
The A2W will give you more safety, wider tune window and the POTENTIAL to make more power. It does come at the expense of more initial investment, in between round maintenance (sucks), extra weight in the car and another fluid that could leak out and cause a crash. Is it needed? No.
My experience with A2A on drag cars: It heats up during the burn out and staging since you are blowing hot air through it and the car ain't movin. It is afterall a heat exchanger. By the time you make the pass, it is very hot and doesn't have enough time to cool off.
For a road race cars, towing rig, etc, A2A might work great since you have a lot of time at higher speed to cool it off, but for drag cars I think it's a waste. And that's speaking from experience.
This is the A2A combo to which I refer, I built it, tune it, fix it, etc. It's got the biggest A2A I have ever seen. It's a Procharger unit that is 6" thick with 4" I/O. If I did it over, it would have either no cooler or A2W:
Old Mar 10, 2011 | 01:34 PM
dreamls1's Avatar
I will be running true street, that's why I wonder if the a2w will be the right choice
Old Mar 10, 2011 | 08:34 PM
05HD's Avatar
That setup is a total failure. Sucking hot air from over one header, pushing it thru a cooler and then cooking it over the other header.
OP, yes, for drag racing an air to icewater intercooler is the most efficient charge cooler.
Old Mar 10, 2011 | 08:42 PM
lafinrat's Avatar
That pic was taken before the car was complete as u may be able to tell since it has no front end on it. It has an intake on the blower that pulls cold air from the cowl area.
Old Mar 10, 2011 | 08:49 PM
98Z28CobraKiller's Avatar
Restricted User
Perhaps a different angle would show better. Looks like a very inefficient setup as pictured because both ends appear to be directly over the headers.
Old Mar 10, 2011 | 09:56 PM
lafinrat's Avatar
You may be right. There is a lot of distance between that pass charge pipe and the header. I'm not exactly sure how I could have plumbed it much different, but oh well. And, this isn't the only A2A big HP car I've tuned. The others have similar high IATs as well.
Old Mar 10, 2011 | 10:34 PM
dreamls1's Avatar
Water to air it is. The for the help guys
Old Mar 10, 2011 | 11:40 PM
Restricted User
The biggest problem that in making this decision is that it is very difficult to see the difference until you try it both ways. We just did a test last night on LS2Formula's car at the track. First made a pass with the A2W empty on 24 psi, then made a pass with it full of ice. Unfortunately, he was having some yet to be determined suspension issues that caused the iced down pass to lose traction and he had to lift or eat the wall and it went on the trailer after that. On the no IC pass we saw 170* charge temps at the end of the 8.3@170 mph run. On the pass with the IC we saw 102* at the end of the 8.6@169 pass. More importantly though was that the EGT temps were 250* cooler on the IC pass.
Old Mar 11, 2011 | 09:37 AM
hellbents10's Avatar
LS1Tech Sponsor
I do not see a reason to run an intercooler with e98, e85 yes on a fuel injected engine.
Old Mar 12, 2011 | 03:37 AM
10sec_rx7's Avatar
7 Second Club
still seeing 102 deg F full of ice??
you sure your temp probes are correct? your numbers dont seem right...
a normal temp is more like 240 deg F with out a intercooler..
i know from my own car not running a intercooler we saw 244deg no intercooler on a 8.2 pass.
with a ice box we see 50deg at the end of a 8.2 pass.
Old Mar 12, 2011 | 12:23 PM
ls2formula's Avatar
I have never seen 50deg temps not even at the start of a run.
Old Mar 12, 2011 | 12:33 PM
Restricted User
Where is your IAT located on the pipe? How far is that from the IC? Like Steve said above, we've never seen temps that low. Not even with 55* ambient air.
Old Mar 12, 2011 | 03:59 PM
10sec_rx7's Avatar
7 Second Club
iat is located just before the throttle body,
we turn 6kg of ice into water per pass. generally after the burnout the temps settle at 45 and rise 5 -8 over the pass
Old Mar 13, 2011 | 09:35 AM
Restricted User
What's the car weigh? How much boost? Trying to get an idea of how much power you're making to get that 8.2 number.
Old Mar 13, 2011 | 05:46 PM
dans776's Avatar
We always pre iced, cooled the i/c down, then drained water and iced back up. 45 degress at start of run and 55-70 @ the end, but this was with a f2 procharger and 38lbs of boost. 7.60's @ 186 on 28/10.5's SBF of coarse
Old Mar 13, 2011 | 06:07 PM
10sec_rx7's Avatar
7 Second Club
car is just over 3000lb, boost was only at 15psi when it ran 8.2@170, turbo is a 91mm gt55. has dynoed well over 1000rwhp but it gets to 1100 and just smokes the tyres
on the dyno had the boost at 28psi and the temps didnt rise a bit, but im guessing at the track the temps will rise another 10-15 with the extra boost and melt another couple of KG of ice each pass..
Old Mar 13, 2011 | 09:13 PM
koolrayz's Avatar
I run a 6" thick A2A 24X12
Highest IAC I have ever seen at the end of a pass in the heat of the summer was 130*
Will an A2W work better sure. I didnt want to **** with having to bring coolers the size of a coffin to the track
Old Mar 14, 2011 | 07:39 AM
LS1Tech Sponsor
I want know of the 9 people who voted have actually ran E98 on a FI car???
