LS1 Rx7 E85 Boost, thoughts?
Old Apr 6, 2011 | 04:30 PM
RexDiablo's Avatar
Default LS1 Rx7 E85 Boost, thoughts?
Hi!
I finally got my rx7 tuned with the 2011 setup.
Search alot but couldnt find any really good info when changing to E85 on a boosted LS1.
I have no read out from my dyno. Why? .. Look here ->
http://www.youtube.com/watch?v=JGStm...layer_embedded
Since i dont have any way to measure horsepower or at least changes in force i have to do some guessing.
I have not changed to E85`s lambda but still using gas. My afr read is 10.8 at wot (boost) and 18 degrees ignition.
Boost is at the moment at 0.65 bar (9.5psi)
Bone stock LS1 engine
What do you guys run? ignition, timing, camspecs etc.
-Sindre
Old Apr 6, 2011 | 05:37 PM
93formto98T/A's Avatar
I'm running e85 in my LSX RX7. You don't need to change anything with the WB02. You will need a better fuel pump and bigger injectors. Otherwise run the same settings on your 02 as you would gas and target for 11.5 afr. My last setup (ls7 w/procharger) liked it closer to 11.1 but the new setup LSX TD w/procharger likes 11.6 afr
Old Apr 6, 2011 | 10:10 PM
carlrx7's Avatar
i shoot for 11.7 or (0.80 Lambda) and 14 degrees of timing at redline
LS2 + Vortech Si @ 10psi
Old Apr 7, 2011 | 07:03 AM
rotary1307cc's Avatar
if you had a strong bottom i would throw quite a bit more timing in than that for good gains
i am at 24* on 7psi right now, last year even with no IC even i was at 24* and 8psi
Old Apr 8, 2011 | 02:05 AM
skinnies's Avatar
On my tc78 5.3 setup on e85 we saw very little gains above 20 degrees timing on e85.
Old Apr 8, 2011 | 06:25 AM
rkreigh's Avatar
very nice setup. as long as you are just a bit rich throw more boost at it.
the e85 will like it
Old Apr 8, 2011 | 02:18 PM
RexDiablo's Avatar
Thank you for good replay!
Nice to know what you guys have. I think i will do some track testing and see what it feels like.
Old Apr 8, 2011 | 02:29 PM
Hank Peabody's Avatar
Thats an awesome way to load the car, I like your other video of the same thing with 18 wheeler tires! Is it all homemade? Cool car too.
Old Apr 8, 2011 | 03:00 PM
kmracer's Avatar
how is that loading the car?
