Got the car back. It made 905rwhp 802rwtq on 13lbs
Old 04-26-2011, 02:12 PM
  #81
turbo iroc's Avatar
I think they're like 500 bucks a piece tho....
Old 04-28-2011, 06:16 AM
  #82
jeremym's Avatar
so i am having some .58 a/r housings being shipped to me. Thanks to josh at KYTP. thank you buddy. so what do yall think about that? should spool nasty!! my cam was speced for the APS kit. (small turbos with small a/r's) so the cam is big enough it should bleed the back pressure. the cam is 250's dur with 620's lift. i would like to peak around 4000-4500RPM and stay flat to 6000-6200RPM. going to the smaller a/r i shouldnt lose top end but bring the power closer right? does anybody have a comparison on switching a/r housings?
Old 04-28-2011, 06:27 AM
  #83
RedVertTA's Avatar
Am I reading this right? You were able to preserve the AC?!!! How and where did you relocate it?
Old 04-28-2011, 10:03 AM
  #84
TracyRR's Avatar
I sure would have thought the .81's would equal insta-spool with a large motor... but the small exh housings will definitely make it spool happy! As mentioned above, the gear change will be a nice change too. Incredible car!!
Old 04-28-2011, 02:33 PM
  #85
Josh@KY-Turbo's Avatar
No relocation needed. Its what I do .
Old 04-28-2011, 02:34 PM
  #86
RedVertTA's Avatar
Impressive, how?
Old 04-28-2011, 02:41 PM
  #87
Impressive, how?
BMR Turbo K-member. Some new A/C Condensor Lines. Thats about it. Plenty of room for the DP to run.
Old 04-28-2011, 07:35 PM
  #88
turbo iroc's Avatar
Are you worried about compressor surge with those small housings? It is a big motor but I think it'll be on the edge...
Quick Reply: Got the car back. It made 905rwhp 802rwtq on 13lbs
