Piecing together procharger set up. Any help appreciated
So i am piecing together a procharger kit. So far i have the D1SC head unit, And a dual intercooler set up, And injectors, I also have a racetronix fuel pump installed, Will this be enough for the fuel pump? Or should i be adding a booster to it?
Aslo as far as i know. I need an inlet hat? What exactly is an inlet hat? is it just the piping for the air filter or is it the air filter? Well i need booth. Unless i can make the one i getting with the head unit work. Witch came off a cobra. And it is reverse rotation. And i know im going to have to switch the location of the oil slinger. "thanks to bob"
Also, Im thinking i may want or need, The radiator plate, And Radiator fan, Also thinking about going with SDCE j bracket. and know im going to need 8 rib crank pulley, and crank pulley, As im assuming im going to need an ati balancer as well? the prochager i have coming is coming with a head unit pulley, but way to small, 3.20 8 rib, and a also gave me a 4.0 6 rib. but that i guess ill just sell. Im thinking im going to need around a 4.24-4.5??
im on a stock motor, It dose have full exhaust, I would like to get as much as i can out of it. While keeping it safe tell i save money for a forged bottom end, Also i guess ill need a boost gauge as well. and of course belts and tune. Other then that? anything else anyone would recommend?
Or if anyone has any of these parts just laying around and wouldn't mind getting them off there hands, let me know.
Thanks! Actually i just installed a lc-1 wide band about a week ago. Though thinking i should get an actually gauge for it as well. I have a EFIlive program or could hook it up to my computer. but im thinking AFR gauge is one i should have, that and boost, And im thinking trans temp? or is there something more important then that? IM looking to buy a pillar with 3 gauges. so
you will need a hat and a filter,talk to bob and he can hook you up if you cant make that one work
ati balancer is highly recomended(make sure you get the one for the supercharger) and a crank pinning kit would also be my suggestion
the fuel pump might be okay but you wont be able to go real far with it
you have to have the single fan setup because of the head unit(but you can add a small one in or pushers on front)
gauges(the more things you can keep an eye on the better)
methanol wouldnt be a bad idea either
do lots of research on here and let me know what you want for that 3.2 8 rib pulley
what is the temp. like in your area on a hot day ?
LS1Tech Sponsor
http://shop.brutespeed.com/98-02-F-Body_c181.htm
I sell most of the piece parts required to put these kits together at the above link. Let me know if you have any questions. Thanks. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
LS1Tech Sponsor
Thanks, I agree! Bob
__________________
With the bracket i also got to switch out my water pump right? Dose that add up cost? i have been also thinking about that bracket as well. Also another thing i was a bit curious about. Is seeing that people complaining about flex? Not that im sure i have to worry to much about it since im only running low boost for now. But rather build it up strong then go back latter if and when i deiced i want to up the boost. I seen Steal j brackets. And also noticed that SDCE had a brave they put in to stiffen it? Is this something i should worry about?
Yes there is a little added cost with swapping the water pump, but when you consider the price of the SDCE plus the cost of a new J bracket to ship them to modify you still come out ahead for an 8 rib system I think with my setup.
I have approached potential flex issues with an added bolt mounting for the blower, and more material on the bracket. I have a few users maxing out D1SC head units without having a problem with bracket flex.
The little pices such as fan shroud, radiator hold down, inlet hat for the blower you can get from Bob, along with my bracket system. I would recommend skipping the Procharger 16" fan and getting a Spal paddle fan, part # 30102082, it is much better at moving air than the one supplied in the Procharger kits. Never had my car over heat when the fan was working.
As far as your fuel pump is concerned, what are your current goals for power? The Racetronix single pump usually only good for somewhere around 550ish hp. Sometimes a little more, but not much.
But as soon as i have funds in a week or two that ill be placing an order with bob for all the remaining parts i need. As for your bracket. I might just end up going that route now. I think you have me convinced
As for my goals. Im thinking the pump will bed good tell deiced to build up a motor for the boost. Im planning on as much boost as i safely can on a stock motor. And while im doing that. just keep my eyes open for parts to build the motor. Probably be 6 months to a year tell i actually get the rest of the parts together. And then go from there. Well that the plan at least.
If you dont have the bracket already definitly do it right the first time and get the Aster bracket.
Also if you dont have the pipping already for the twins, i would sell the twins and go with a front mount. and get the better SPAL fan besides the procharger fan.
i would also download the procharger manual from bob. i think he still has it on his website. by carefully reading through the manual you can see what parts you have and which parts you still need to get. it can be difficult to piece a procharger kit together unless you have experience installing them. i was constantly finding new parts that i didn't have and i didn't know that i needed. the slight cost savings was not worth the hassle in my opinion. good luck!
Please correct me if im wrong. But if i have the intercooler and all the pipping for it. And the bov on it as well. Actually i have two of them. One came with the head unit i bought was well. And the head unit. I just have to pick up, Inlet hat, filter, And actually i have a filter that came with the unit that ill try, i got to get the balance and the crank pulley and a pin kit. And then the radiation fans and bracket, And then the right pulley on the head unit. and the Aster bracket, and a belt. But really what more is there besides this? Besieds tune and injectors. Witch i also already bought. well injectors any ways. The guy who sold me the head unit sold me some for an extra 200$ some Sieman deka 60lb, Witch under 5k miles on it. same as the D1SC i bought off of him.
But then again this is why i made this thread. Because i am totally new to this. And i could be totally wrong. And missing things. But fear none because all the help i get from everyone here. And just reading post of previous people
LS1Tech Sponsor
Personally i enjoy piecing it together. Ill get the exact system i want this way. Maybe ill feel different when im done. But i don't see it being that many parts.
Here is an older copy of the LS1 F Body ProCharger installation instructions. The 8 rib balancer used these days is a 918853 part number, and disregard the fmu (fuel management unit) installation. Bob
__________________
You may be better off piecing it together. I thought I had all of the pipes/plumbing, but I didn't. I was missing one part here and there. I didn't realize it until I needed to install the part, and then I didn't have it. It isn't a huge deal. Maybe I am too impatient. haha.
http://www.ls1.com/ed/procharger_owners_manual.pdf
LS1Tech Sponsor
You're welcome, thanks! Bob
__________________
So my build might be put off a bit longer. I thought i was getting money back this year on taxes, And found out last week i owe. OUCH! So in the mean time, If anyone has a part or two they want to sell ill keep piecing it together. Until i have the money to buy the rest from bob.
