Is partial boost possible at part throttle with a Procharger?
I'm in the process of putting together a D1SC with a FMIC for my car. My current FI experience is only with my daily driver which is a Saab 9-3 that has a turbo charged 4-cylinder. With that, I don't have to give it too much throttle to start making boost, which makes the car quite lively, especially for a 2.0L 4 cylinder.
So I was wondering. Is there a way to have a procharger make boost at part throttle conditions or is it a WOT or nothing type thing? From what my understanding is, what regulates when you get boost is the Pro-Flo valve, which is vacum operated, so it stays open when you are under vacum but then closes once you go WOT. Is there a way to make that close sooner? I'm sure there is a way, but has anyone done it?
Thanks.
I know what you mean by the turbo giving you part throttle boost, I drove a guys EvoX and it was weird having boost at liek 60% throttle.
Don't believe there is anyway to make boost faster.
So from the way it sounds, a procharger is essentially like having nitrous in that you only get the added power at WOT. If that's the case, I may need to rethink this.
At 2000-3000 yea, I have to mat it to get boost.
at 6000, I barley touch it and it goes into boost.
at 4000, You can still give 1/4 - 1/2 and get into the boost.
So my point is this. I've got a decent NA setup right now. The cam and heads are a good combo making good part throttle power and throttle response. By adding the procharger, I should see more power/torque than I currently have even if I'm not at WOT, right?
buddy had a srt-4 with a 70mm turbo on it, no power under 4k but at 4500 holy you know what. car could make lane changes with the throttle the boost came on so hard.
Don't know if that makes any sense but seems logical to me.
As you roll into the throttle, the manifold vacuum can drop low enough that the bypass will close & the charger will force air into the engine, so you can get some boost at part throttle. Not a lot of boost, but it is not uncommon to see maybe 1# at 2500-3000rpm. It will make the car feel much more responsive even though it is not the same amount that the car sees at full throttle.
Thanks everyone for the comments.
But if you can restrict yourself to not go WOT, yes, you will still see boost, and you will feel more airflow, even if you are not into boost yet if that makes sense? Hard to describe it to someone who has not driven a procharged car, but bottom line, you will have more power throughout the whole RPM range and at any throttle position compared to any N/A setup.
But if you can restrict yourself to not go WOT, yes, you will still see boost, and you will feel more airflow, even if you are not into boost yet if that makes sense? Hard to describe it to someone who has not driven a procharged car, but bottom line, you will have more power throughout the whole RPM range and at any throttle position compared to any N/A setup.99% of the time I drive my car it's on 2 lane backroads with lots of curves, twists, dips and such. So I considered going bigger cubes for a while because after looking at log after log after log of my driving, I realized that most of the time I was accelerating at between 40-50% throttle and shifting between 3500-4500 rpm. Now I know that a procharger might not be the most ideal setup, but it was something that I knew I had the skills to do in my own garage and was going to be considerably less expensive to do than a bigger cube motor.
I will still enjoy the romp to 6000+ rpm from time to time, which I know is when the procharger will shine, but I just wanted to make sure that it wasn't going to be like nitrous where it's all or nothing and only there at WOT.
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
(Sorry for the hijack - it should be a yes-no answer!)
