Wastegate mounting?
Old Apr 16, 2011 | 02:00 PM
Novaray64's Avatar
Default Wastegate mounting?
Will it hurt anything to dump the wastegate stright into the down pipe or
should I redo this at more of an angle Ive already got the one side all
welded up
Old Apr 16, 2011 | 06:35 PM
98Z28CobraKiller's Avatar
Restricted User
Certainly, It would be better if it angled in but ultimately it will really depend on how restrictive the exhaust is.
Old Apr 16, 2011 | 06:37 PM
Restricted User
Also, please post more pictures of your setup. Got a buddy that is building a turbo 64 Nova that would love to see how you have it in there.
Old Apr 16, 2011 | 06:57 PM
robbyredneck's Avatar
looks ok to me. how much boost and what size turbos? nice lookin bay btw
Old Apr 16, 2011 | 07:31 PM
rotary1307cc's Avatar
Closer to the turbine discharge the worse it is too, you are going to be creating alot of turbulence where you don't want it like this
Old Apr 16, 2011 | 08:20 PM
yessir's Avatar
why not just clock the gate and make a smooth merge
Old Apr 16, 2011 | 09:29 PM
madmax4499's Avatar
you will be fine. what are your power goals? is that a 3" down pipe?
Old Apr 16, 2011 | 10:12 PM
Novaray64's Avatar
Right now I am using a stock JY 100K long block and am looking for 600rwhp
but will be upgrading to a forged bottom end some day
turbos are precision 6265 with a 3" down pipe the pic I posted is a old one
ive welded up the wastegate pipeing on the one side and the other is all tacked up other wise I would rotate the wastegate and make it a smoother transition
thanks for the help
