CBR F2 System First Install
The only changes to the kit that I see needs to be done is headers, charge air pipe
coming from the inner finder to the throttle body and motor mounts.
My DD is a 96TA.
When I get a break I'm going to put one on my car.
If you are searius about it contact Rod and he will work out the details with you.
10.97@128mph with a 1.80 60FT. @11psi
This was leaving on no boost. The car was a handful to stage
and keep it from pushing through the lights
We got kicked off the track after 3 pass's due to no cage.
We need to do some tuning to the shift points on the 4L80E.
It is shifting a little late from 1-2 and way late 2-3.
The 2-3 shift is about 6500 and it needs to be about 5500.
The car noses over real, real bad on the 2-3 shift.
Adrian is going to get the tune adjusted so the trans shifts in the power band.
If all goes well we will take it to another track this Sunday.
This other track don't care how fast you go, you pay, you race!!!!
All in all it was not bad for a first time out. I think the car has mid 10.70's in it
if we get the trans to shift on Que.
That's all for now.
Chris
You need to get those vids up Chris.
LMAO
