CBR F2 System First Install
Old Jun 3, 2011 | 03:03 PM
  #141
Chris@CBR's Avatar
That's not my choice. I asked them to ask there tuner how he prefers to do it.
He told them that he could do it with the meter. I suggested that they do a SD tune but it's there car and there money they can do it anyway they like. We will have a 2 bar map sensor on hand just in case the tuner misunderstood them or has a change of heart.
IMO I think a SD tune is the best way to go for any FI car.
Tuners are like doctors everybody knows the best one.
Old Jun 3, 2011 | 03:19 PM
  #142
LilJayV10's Avatar
When something goes wrong I wonder who they will blame first. You or the tuner.
Old Jun 3, 2011 | 03:40 PM
  #143
Johnv's Avatar
At the end of the day it's a std bottom end LS1, and this kit has waaaaaay more potential than a std bottom end can handle.
So i'm sure boost and power will be limited to within the realms of safety and And the owner should be aware that any time you add boost to a std engine there is an element of risk.
Old Jun 3, 2011 | 04:29 PM
  #144
revtech101's Avatar
^With a powerful kit like this, it wouldn't matter if it is a stock motor or not. It can break ANY motor if things do not go as planned.
Old Jun 7, 2011 | 05:37 PM
  #145
mrws6speed's Avatar
Hi Rob,
It was a pleasure talking to you. You have definitely thought of all the little details that make this the ultimate kit.
Little things like a K-member designed so alignment shops can work on it, keeping the kit quite & streetable and having it so a car like mine doesn't get hacked up in the process is exactly what I've been looking for.
I pray you have great success in this and all your ventures. I look forward to talking to you in the near future as I get things lined up.
Old Jun 13, 2011 | 05:27 AM
  #146
Chris@CBR's Avatar
Ok guys a little update.
I want you guys to take notice on how clean and professional looking the mods to the frame looks. Jesse and Ryan are top notice guys when it comes to things like this.
If you weren't a F-body guy and the places that where moded had paint on them they would look like GM made it that way.
The car is getting a 4L80E and I stopped by the shop over the weekend to take a few pic's.
In this pic you can see where the uni-body frame the goes over the trans had to be notched to make room for the main electrical plug on the left and the notch on the right is for the rear cooling line.
That yellow stuff you see is 3M welding paper covering the fuel lines and other things.
Driver's side detail
Passenger side detail
Driver's side detail with trans installed,
Passenger side detail with trans installed, no oil return fitting is installed in this pic but the frame notching is necessary.
In this pic you can see that there is a tab that has to be removed and the ear needs trimming to get the 4L80 to fit the F-Body in the bell housing area, this was done on both sides. This trimming had nothing to do with the turbo kit, this needs to be done to get it to fit the F-body floor pan.
Notice the paper and tap on the input shaft of the tranny, This is done to keep any welding and grinding debris
out of the new tranny.
Jesse and Ryan always go the extra mile to do it right.
Good work guys
We are still waiting on a convertor so as soon as it comes in and if there are no surprises
we should me dynoing this thing very soon, hopefully by the end of the month.
Stay tuned!!
Old Jun 13, 2011 | 11:00 AM
  #147
87silverbullet's Avatar
Dammit why the end of the month Chris! I won't be able tag along and see it on the dyno.
Old Jun 13, 2011 | 12:46 PM
  #148
Chris@CBR's Avatar
Jesse is taking his vacation this week and the convertor hasn't showed up yet.
That didn't come out of there mouth about the end of the month that is me be optimistic.
Old Jun 13, 2011 | 03:39 PM
  #149
Getting married at the end of the month and with the honeymoon i won't be back for awhile. Hopefully I will be back in time to see it.
Old Jun 24, 2011 | 06:01 PM
  #150
Thule's Avatar
for 10k i would get the kit like i see it on the pics? w/that oil cooler, that K member and everything i would need to install it?
Old Jun 24, 2011 | 06:06 PM
  #151
ModularTurbo's Avatar
It comes with all of that.
Read this:
https://ls1tech.com/forums/new-produ...ocharging.html
Old Jun 24, 2011 | 07:18 PM
  #152
rjparth's Avatar
Damn! After 8 pages this thread just left me with blue *****. The kit looks awesome. The attention to detail is stunning. Can't wait to see the end results!
Old Jun 24, 2011 | 11:33 PM
  #153
WS6sleeper's Avatar
I'm dying to see this thing RUN!
Old Jun 25, 2011 | 10:05 AM
  #154
sykodrummer9800's Avatar
sweeeeeet i want one......
Old Jun 25, 2011 | 10:33 AM
  #155
2 kits in stock call me
Old Jun 28, 2011 | 12:48 AM
  #156
Johnmaster's Avatar
MASS seller approved
Top notch attention to details guys. Good work!
Old Jun 29, 2011 | 07:09 AM
  #157
Fuel pump wiring harness
Fuel lines and fuel pump wiring harness routing
Ran inside of the heat shields
Secondary fuel pump trigger screwed into one of our charge pipe provisions
Fuel Pressure regulator mounted to the brake booster
Driver side wheel turned all the way to the right
(factory gm 17"x9" wheel)
Splash shield trimmed for the charge piping
Passenger side wheel turned all the way to the left
Splash shields trimmed for the charge piping
Splash guard trimmed for intake and charge pipes
Factory smog pump used for Crank Case Evacuation
4" exhaust
Mufflex 4" exhaust w/ a Magnaflow muffler
Going over the rear end
Muffler connection
Tail pipe
Factory air dam for the radiator completely unchanged and all stock
More awesome stockness!
Old Jun 29, 2011 | 10:26 AM
  #158
LilJayV10's Avatar
That's clean looking.
Old Jun 29, 2011 | 01:55 PM
  #159
mrws6speed's Avatar
Quit making me want one!
Old Jun 29, 2011 | 04:52 PM
  #160
Chris@CBR's Avatar
I shot these pic's Monday morning, all that's left is to tie the pump into the valve cover
and a few nick nacks and we are ready for a tune!!
