Tourquer V2 cam and boost? EPP? Brute Speed?
Old Apr 27, 2011 | 09:26 PM
Blownz28man's Avatar
Default Tourquer V2 cam and boost? EPP? Brute Speed?
Hey guys haven't had much luck with anybody schooling me on if this cam will work. I'm building a forged 347 with a TC78 turbo, auto car, 3.5" exhaust to a 4". 3400LBS ect... Heres the specs on the cam.. Its on a 114lsa 232/234 .595/.598. Am i better selling t and going with a Brute Speed cam -Dur @ .050 232 int 240 exh Lift 595 int .608 exh and a 115lsa. Or EPP blower cam?? I've dont some searching but no luck.
Old Apr 27, 2011 | 09:37 PM
tripblackls1's Avatar
figure out what your overlap is with it, from my research i have found that 8* of overlap is the most that you want, anything more than that is not good for the cam to be optimal for turbo motor
Old Apr 27, 2011 | 10:01 PM
Really don't know what the overlap on the cam is. Cant find it aywhere on the web. I'll have to call TSP tomorrow.
Old Apr 27, 2011 | 10:07 PM
Wnts2Go10O's Avatar
the Tv2 is fine for boost. not the best but not the worst either. on a 113LSA Tv2 its 7 degrees overlap @.050
cam card:
https://ls1tech.com/forums/attachmen...orquer-v.2.jpg
its been awhile since if done the research on turbo cam stuff but its all here. IIRC, no split and lower exhaust duration helps spool.
Old Apr 28, 2011 | 10:26 AM
I Think mine is on a 114lsa. There's just not a lot of people running my cam. I'd just like the right combo the first time.
Old Apr 28, 2011 | 10:30 AM
XtremeDime's Avatar
I got frustrated trying to find the answers to questions like these and just bought a turbo cam from VA Speed.
Old Apr 28, 2011 | 10:35 AM
rjparth's Avatar
I believe EPP blower cam and Brute Speed FI cam are the same thing. Bob's old shop vs. Bob's new shop.
Old Apr 28, 2011 | 11:41 AM
MUSTANGBRKR02's Avatar
I ran the Torquer 2 on my car for about 5-700 miles and it pulled crazy in the higher RPM's I only got rid of it due to going with a new motor.
Old Apr 28, 2011 | 11:44 AM
See I have my motor apart right now. So I'm kinda in the same place as you
Old Apr 28, 2011 | 12:19 PM
KnightmareLS1's Avatar
I have that cam in my car, details are in sig. Not optimal for FI but will DEF work/make some power
Old Apr 28, 2011 | 01:14 PM
Wnts2Go10O's Avatar
no ****.. awesome numbers for the boost level..
Old Apr 28, 2011 | 03:36 PM
Nitroused383's Avatar
Shoaf85 ran a torquer 2 cam with his TC76, made almost 600 rwhp on 8lbs of boost.
8lbs
http://www.youtube.com/watch?v=H0hPMuMzRS8
Old Apr 30, 2011 | 06:31 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
http://shop.brutespeed.com/Comp-Brut...n-Camshaft.htm
Here is our blower cam that is talked about in this thread. Thanks. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old May 4, 2011 | 05:45 PM
Thanks Bob, The cam sounds great.. But I think it may fight the combo? I know a TC78 has less lag then bigger turbo cars and may start dropping off when others are at full stride. Maybe a smaller cam is appropriate? Lower lift and duration?
Old May 4, 2011 | 06:47 PM
LS1Tech Sponsor
Possibly, although this cam seems to normally peak a little over 6200 rpm. Bob
__________________
Old May 6, 2011 | 04:08 PM
XXX37's Avatar
how would that cam work in a TT 4.8?
