cam question with gt35
Old May 14, 2011 | 05:45 PM
LTXBOI's Avatar
Default cam question with gt35
218/218 .544/.544 114lsa for lt1 forged 355ci 8.5:1 compression twin gt35r would you run this cam yes/no and why not?
Old May 14, 2011 | 05:53 PM
LTXBOI's Avatar
forgot to mention this is a street/strip projekt!
Old May 15, 2011 | 03:44 AM
LTXBOI's Avatar
If not this cam what would you recommend goal 600+
Old May 15, 2011 | 11:29 AM
Fondle's Avatar
i think the cam is a great boost cam, but maybe a little small. You could go bigger and reach your goals with less boost
Old May 15, 2011 | 12:55 PM
kornboy's Avatar
I would stop it all and start fresh with a real motor the ls1 you would not have to do any thing and have more power than you already have with your current setup
Old May 15, 2011 | 05:32 PM
LTXBOI's Avatar
well this is not a ls1 motor nore will i ever want to put a ls in my 97 camaro..If you dont have any real input please troll some where else!!!!
Im not apart of the ls1 bandwagon committee sorry
Old May 15, 2011 | 05:33 PM
LTXBOI's Avatar
ok cool what would be a good cam for my expectations?
Old May 15, 2011 | 05:46 PM
Fondle's Avatar
I am not super familiar with lt1 engines, but i would get something with more lift
Old May 15, 2011 | 06:07 PM
kornboy's Avatar
Dude im just joking with you its what I do when im jealous.. im only running the booty mount and dreaming of the day I move forward.. that is move the turbo forward to its proper location.
Old May 15, 2011 | 06:53 PM
4SFEDZ's Avatar
i think thats on the small side, im running a, .570 .610 236/244 on a 112 its an old lpe boost cam. it did well when the car was a 6 speed street car, and has done well now that the car has a th400. i made 670 to the wheels thru a th400 and s60 @14 psi. pump gas and no meth. and this is with a 75mm turbo. so no, id get somethung bigger!
what tranny? whats the ultimate goals for the car, and dont kid yourself. dont do it twice, do it right the first time! but if 600 is all your after that cam will prolly be fine.
Old May 15, 2011 | 08:07 PM
LTXBOI's Avatar
lol the booty mount....Hows that working for you.have a freind that wants to fab up his own sts kit on his ls motor.
Old May 15, 2011 | 08:15 PM
LTXBOI's Avatar
my goal is 600+ is your cam specs with 1.6rr.Thinkit could be a good cam with a 114lsa? the cam i asked about would come out to 220/220 .580/.580 114 LSA with 1.6rr
Old May 15, 2011 | 08:22 PM
Snyper's Avatar
I know its a different engine but im running a 228/228 .588/.588@114 and it has excellent street manners. Your cam sounds a little on the small side. I would stick with something closer to mine or at least a 224/224.
Old May 15, 2011 | 10:47 PM
4SFEDZ's Avatar
yes mine is with 1.6rr
Old May 16, 2011 | 03:41 AM
LTXBOI's Avatar
sound like a good cam I emailed isky cams I may be going with your cam specs though based on what info isky gives me tomorrow...thanks
