keep 370 OR just build the 408
Old May 29, 2011 | 09:34 PM
rossi89's Avatar
Default keep 370 OR just build the 408
Got my lq4 block ready to get machined. I am building a turbo motor and am leaning toward the pt88 turbo. Should I keep the 370 cubes or just go the 408 route? Any Suggestions?
Old May 29, 2011 | 10:17 PM
westtexasbuff's Avatar
My vote goes to just staying with the 370.
Old May 29, 2011 | 10:31 PM
TracyRR's Avatar
i agree^^^370
Old May 29, 2011 | 10:46 PM
PRAY HRD's Avatar
370 as well. I'm worried how many rpm's my pt88 will hold me to with my 402 when it's ready to get put together, due to back pressure. If you go with a 408 and wanna spin it high, go with a 91 or an 88 with a t6. It would be cheaper with the 370 as well since you can use your stock crank.
Old May 29, 2011 | 11:30 PM
rossi89's Avatar
Thanks guys for the suggestions!
Old May 30, 2011 | 12:08 AM
01Z28Camaro's Avatar
370 for sure, I just went from a 408 to 370 and love it.
Old May 30, 2011 | 07:01 AM
dreamls1's Avatar
370!!!
Old May 30, 2011 | 07:58 AM
OUTLAWZ RACING's Avatar
was a 370 said?
Old May 30, 2011 | 10:11 AM
rossi89's Avatar
Thanks guys. 370 it is
Old May 30, 2011 | 10:15 AM
gsxr1k2's Avatar
What are the benifts going back down? I love all the power/tq before the turbo spools with my 404.
Old May 30, 2011 | 10:58 AM
Sweet_SS's Avatar
Can I ask why a 370 is better then a 408? I'm going to assume that you can spin a 370 much higher then a 408? I thought the turbo would do better with more cubes.
Old May 30, 2011 | 11:10 AM
rotary1307cc's Avatar
Stronger pistons for one...... and you better have a lot of room available to fit a system big enough to keep 400+cid happy and not choked
Old May 30, 2011 | 11:19 AM
You summed it up for me. My 408 with the pt88, I could never make it work on the street how I wanted, it would spin bad then when it finally hooked I had to shift anyway cause it starts to hit a wall from back pressure.
Now it dead hooks and stays hooked, doesn't just blow the tires off and I'm talking about stock rims with just some 26 inch 275/40/17 nitto 555r. An it pulls hard to 7000 rpms. I don't have to worry about the back pressure as much and my egt going through the roof.
Old May 30, 2011 | 11:25 AM
MUSTANGBRKR02's Avatar
I want a pt88 for my 370 I just have a tc78.
Go 370 with the 88 it's enough power to go into the 8's with the proper set up.
Old May 30, 2011 | 12:28 PM
gsxr1k2's Avatar
Jose strongly recommended that I stay away from the pt88 (which is what I originally planned). He said that I would see insane back pressure with it like your saying. i haven't had a chance to really turn up the 91 yet but paired with the eboost2 I don't see why you cant make a 400+88-91mm setup killer on the street.
Also where were you monitoring your egts from?
Old May 30, 2011 | 12:34 PM
gsxr1k2's Avatar
Where do you get this information backing that statement about piston strength?
Old May 30, 2011 | 01:32 PM
Reject's Avatar
man no love for the 408 huh. what about a 383 lets stir the pot alittle
Old May 30, 2011 | 03:12 PM
Sweet_SS's Avatar
Makes sense. Thanks for the clarification.
