Opinions on water pump for a custom a2w setup
I am currently in the process of upgrading my vortech system to a YSI head unit and a custom front mount a2w intercooler with a 5 gallon tank in the hatch. What I am wondering is what GPH pump should be used? I know the stock vortech ones are in the low hundreds, and the chiseled performance ones are in the 1500-2000 range. I purchased a rule 360gph pump but am now having second thoughts. Some input on what has worked or even a comparison if someone has started small and upgraded to know if a higher flowing pump will lower iat's and by how much. Any help is greatly appreciated! Thanks, Matt.
im using the meziere remote pump on my app i have a 10 gal on the bed of my truck pumps all the way forward to the heat exchanger thru the sc back to the bed and still looks like you have a water hose on in the res.
I think youre fine with your current pump...but if youre looking to upgrade the rule 2000 is a very nice pump, alot of high hp/tq guys are running them. Try yours out for a while and if you dont like it, like I said, the rule 2000 would be the choice unit imo.
My car made the 772 at 16 lbs. My IAT's on a 1/4 pass do hit 170 which is high, that is after doing a complete ice down prior. I'm not sure if a higher flowing pump like the Meziere would help or the Vortech aftercooler is simply overwhelmed I'm leaning toward the latter.
