TU1 vs. TU2
Old Jun 11, 2011 | 08:53 AM
buick_lsx's Avatar
Default TU1 vs. TU2
TU1 225 225 .581 .581 113
TU2 236 236 .587 .587 112.5
for a 370 motor where would these two cams make peak power at?
Also, how much power would you be giving up by going with the smaller cam?
I know you dont need a big cam for a turbo but if im giving up a bunch of power thats a problem lol.
I currently make 600rwhp with 9psi and ls6 cam, just wanting a larger cam to gain power without upping the boost, and want a "meaner" idle as well.
Old Jun 11, 2011 | 09:41 AM
JAX04's Avatar
In, ive been eying these two cams for awhile, they sound great too
Old Jun 11, 2011 | 10:07 AM
MUSTANGBRKR02's Avatar
I have two same builds with the 370 and TU1 I plan on switching one out for a TU2 to see the difference between the two later on in the fall. I know this doesn't help now but I have been wondering also if I am leaving some on the table.
Old Jun 12, 2011 | 12:40 AM
qqwqeqwrqwqtq's Avatar
What turbo and power level? Up to a single 76 and 900rwhp you're not leaving much if anything on the table with the TU1.
TU2 has made 1150+rwhp with twin 67's for reference.
Old Jun 12, 2011 | 05:25 AM
buick_lsx's Avatar
Would it make a difference for a larger motor? 390 or 408?? Or more of just the HP desired.
Old Jun 12, 2011 | 10:27 AM
What turbo and power? It depends on the combination.
For instance, TU1 and 76GTS on stock displacement will make over 900rwhp.
Run the same 76GTS on a 408 and it will choke due to backpressure before it hits 900rwhp regardless of the cam.
Old Jun 12, 2011 | 11:08 AM
madmax4499's Avatar
WOW, i cant wait to see what the TU-3 is going to do for my build.
Old Jun 12, 2011 | 03:58 PM
buick_lsx's Avatar
Well ultimate goal is that 1000rwhp mark on race gas, but would be ran more often on pump gas.
Just a s475 now but would be a s480+ later on
Old Jun 12, 2011 | 04:00 PM
Superman09's Avatar
LS1Tech Sponsor
any PTV issues with the TU2 on stock or 6.0l heads?
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Jun 13, 2011 | 09:31 PM
LT1 ANDY's Avatar
Ive got a TU1 going on a AFR Headed 370 with t6 88mm deal, should I have stepped up a bit. Im sure it will be functional. But the motor isnt in the car yet and i could still make a change if needed.
Andy
Old Jun 14, 2011 | 07:44 PM
robbyredneck's Avatar
if you need to unload that cam andy let me know.
Old Jun 15, 2011 | 08:01 PM
willizm's Avatar
I went with a TU1 and am shooting for 750whp on built 5.7 ls1 bottom end. You have a few more cubes so you might benefit from a TU2. Not sure though, call speed inc and ask. I'm sure they'll point you in the right direction.
Old Jun 16, 2011 | 02:27 AM
buick_lsx's Avatar
I guess I'll call them here in a few days...I'm sure the TU1 is good for the 370 but this winter I will be going to a 390 and don't know if the extra size will need the TU2 or not.
I only want to buy it once lol
