Turbo FMIC people...where did you mount your trans cooler
I need to order a transmission cooler for my 4l80e. I have a front mount 27 x 15.5 x 4" intercooler with about 6" between it and where my vertical AC condenser/radiator will be. I am running slim puller fans, so mounting the trans cooler after the radiator wont work, and I worried that mounting it between the intercooler and radiator assembly would obstruct airflow (just a theory, correct if I am wrong). My only other option would be a remote trans cooler with a small fan mounted to it. not only is it more expensive for that setup, I would prefer to not have to find a place under the car to mount it (lowered). I was looking for advice from you turbo guys who had to deal with a similar setup.
I have mine mounted under the passenger side floorboard. It's a B&M 28k cooler with a thermostatically controlled fan that kicks on at 180 and won't cut off till 170. Keeps the car cool in the staging lanes at 180-190 all day and after a pass.
I can even sit in the lanes with the car off since it's wired to run hot and it will cool it at a standstill off or running. I accredit this to the big cooler, but it works.
