LSX alternator relocation kit
Old Feb 4, 2013 | 12:49 PM
  #261
KissMyTushZ28's Avatar
Has anyone compared this to HawksThirdGen Relocation kit? It's the only one I've ever seen before this(excluding DIY kits). And do I order by phone or can I online? Looks like an awesome kit!
Old Feb 4, 2013 | 01:22 PM
  #262
bRAZENLS2gOAt's Avatar
Will these fit on the 05/06 GTOs with electric TB's?
Old Feb 4, 2013 | 01:29 PM
  #263
LT1RAY's Avatar
I have one and it works good but Huron Speed also makes a great kit.
Wonder why they aren't a sponsor any more?
Old Feb 4, 2013 | 04:59 PM
  #264
You have a hawksthirdgen or one that's shown here?
Old Feb 4, 2013 | 06:51 PM
  #265
Boosted Firehawk's Avatar
Who makes a kit for the crank and alternator only? NO other accessories driven or water pump.
Old Feb 6, 2013 | 11:04 PM
  #266
meatheadgn's Avatar
Bump, I need about the same thing but just need the alternator and water pump to be driven.
Old Feb 8, 2013 | 09:33 PM
  #267
ModularTurbo's Avatar
our kit has a built in tensioner, you should be able to use it for that
Old Feb 8, 2013 | 10:39 PM
  #268
Hey modular. So just with my stock ls1 I can do this relocation just to make things easier for next time and not need anything special or any specific reason?
Old Feb 9, 2013 | 11:54 AM
  #269
LILHEMI's Avatar
Correct.
Old Feb 9, 2013 | 02:44 PM
  #270
Suhweet! Definitely going to do this whenever I have to change my alternator next.
Old Feb 21, 2013 | 05:20 PM
  #271
fastcars95's Avatar
PM sent
Any plans on another group buy ?
Old Feb 21, 2013 | 05:27 PM
  #272
dean85gt's Avatar
Can you make one of these for corvette accessory spacing?
Old Feb 24, 2013 | 11:41 AM
  #273
s25hanh's Avatar
Originally Posted by fastcars95
PM sent
I'd be in on it.
Old Mar 10, 2013 | 08:58 AM
  #274
fastcars95's Avatar
Has anyone used one of these with a set of fabricated valve covers ?
Its hard to tell if the alternator will clear the valve caver.
Old Mar 10, 2013 | 07:37 PM
  #275
We had a customer that called us and said that the stock F-Body ALT was hitting his sheet metal valve cover. We suggested that he try the smaller CS130.
It is a little shorted than the F-body ALT. We haven't heard back from him.
It depends on how the valve cover is made. If the sheet metal is welded to the outer part of the gasket rail it will not have the same clearance as one that is welded to the inner part of the gasket rail.
The ALT has to be spaced so that the pulleys line up, one brand of relocation kit
is not going to be better than another as far as this is concerned.
The older CS130 is shorter, it will give you the most clearance.
Old Mar 14, 2013 | 08:08 PM
  #276
WSex's Avatar
can i buy one without the belt? because i have an underdrive pulley and no p/s.
please email me at marior93@me .com
Old Mar 16, 2013 | 08:48 PM
  #277
jrpimp00's Avatar
Got mine installed and so far, its perfect.
Old Mar 17, 2013 | 09:42 PM
  #278
Br1_ss's Avatar
Just bought mine today. I'm running Proform Valve covers which are the taller ones.
Old Apr 1, 2013 | 11:22 AM
  #279
Zfan's Avatar
Was wondering if the kit will work with a L76 build that I am slapping in my 240Z
Old Mar 5, 2014 | 10:01 AM
  #280
Midnight02's Avatar
Subscribing to this one. After dealing with the need to remove the stock alternator, the idea of relocation is tempting.
